Easiest way to control the speed of a motor?
Hello everyone! I was thinking of building a scooter device sort of like a segway. I way going to buy this http://tinyurl.com/6tybtbv motor. It is 750 watts. What is the easiest way to control the motor from a Arduino digitally? Do I have to buy a motor controller?
Thanks! Tyler
36V 750W DC motor. Yes you will need a motor controller and some serious heatsinking. Good luck finding one that goes up to 36V. The Monstor Motor Shield sold by Sparkfun will cover your current requirements, but it only does 16V...
Thanks for the info :slight_smile: Sorry, I’ve been trying to google for info about controlling a motor, but everything I find is about small servo motors. :~ Are there any specific keywords that could help?
Thanks!
Tyler
Have you tried "electric scooter parts"?
www.4qd.co.uk will astound you with the amount of information they provide on motor control. As an aside they also have a suitable controller for your application. Using a 5 volt drive from your arduino it’ll give you all you need plus regen braking. I’ve no commercial interest in the company, just a very happy customer.
http://www.pololu.com/catalog/category/82
jackrae: www.4qd.co.uk will astound you with the amount of information they provide on motor control. As an aside they also have a suitable controller for your application. Using a 5 volt drive from your arduino it'll give you all you need plus regen braking. I've no commercial interest in the company, just a very happy customer.
Thanks for the info! :) Sorry, what is a "5 volt drive"?
But the prices seem high. The "Pro 150" is 140 pound = $225 I can't afford it :~
[quote author=Coding Badly link=topic=106315.msg797843#msg797843 date=1337329723]
[/quote]
That website looks good, thanks!
If I buy a used scooter could I use the motor controller that's inside it with an arduino?
Thanks!! Tyler
I found the below for $54.95.
CT-660B9 36V 1000W Electric Scooter Speed Controller Designed for 36 Volt motors up to 1000 Watts. Maximum current 40 Amps. Under Voltage protection 31.5 Volts. Current limiting feature prevents controller and motor damage due to over-current conditions. Under voltage protection feature prevents over-discharge and extends battery life. Uses standard 3-wire variable speed hall-effect throttle. Fits many common electric scooter and bicycle models. Item # SPD-CT660B9 Wiring Directions
