East Rising RA8755 resistive touch screen
Hi all,
I have got this screen working with my Mega2560 through the SPI bus, displaying images works fine but I'm having trouble with the touch screen, I'm using sumotoy's library and have edited the usersettings file (#define USE_RA8875_TOUCH) but I am unable to get the touch screen to respond. I am using the easy paint example sketch to test the touch screen
/* Touch screen super-easy paint!
  This version use the new touch screen functions, much easier!
  Did you have already calibrated your screen? Better do as soon you can
  Open TouchScreenCalibration example and follow instructions.
You are using 4 wire SPI here, so:
 MOSI:11
 MISO:12
 SCK:13
#include <SPI.h>
#include <RA8875.h>
#define RA8875_INT 2 //any pin
#define RA8875_CS 53 //I'm using a Mega2560
#define RA8875_RESET 9//any pin or nothing!
RA8875 tft = RA8875(RA8875_CS,RA8875_RESET);//Teensy3/arduino's
uint16_t tx, ty;
void interface(){
  tft.fillRect(10,10,40,40,RA8875_WHITE);
  tft.fillRect(10+(40*1)+(10*1),10,40,40,RA8875_BLUE);
  tft.fillRect(10+(40*2)+(10*2),10,40,40,RA8875_RED);
  tft.fillRect(10+(40*3)+(10*3),10,40,40,RA8875_GREEN);
  tft.fillRect(10+(40*4)+(10*4),10,40,40,RA8875_CYAN);
  tft.fillRect(10+(40*5)+(10*5),10,40,40,RA8875_MAGENTA);
  tft.fillRect(10+(40*6)+(10*6),10,40,40,RA8875_YELLOW);
  tft.drawRect(10+(40*7)+(10*7),10,40,40,RA8875_WHITE);
  //while (!Serial) {;}
  Serial.println("RA8875 start");
  tft.begin(RA8875_800x480);//initialize library
  tft.useINT(RA8875_INT);//We use generic int helper for Internal Resistive Touch
  tft.touchBegin();//enable Touch support!
  if (!tft.touchCalibrated()) {//already calibrated?
    Serial.println("Maybe better you calibrate first!");
  //this enable an ISR on CPU and RA8875 INT
  tft.enableISR(true);
  interface();
uint16_t choosenColor = 0;
  if (tft.touched()){//easy!
    Serial.println("Touched");
      tft.touchReadPixel(&tx, &ty);//read directly in pixel!
      if (ty >= 0 && ty <= 55){ //interface area
        if ((tx > 10 && tx < (10+40))){
          choosenColor = RA8875_WHITE;
          interface();
          tft.fillRect(10,10,40,40,RA8875_BLACK);
          tft.fillCircle(tft.width()-10,10,5,choosenColor);
        else if ((tx > 10+(40*1)+(10*1) && tx < 10+(40*2)+(10*1))){
          choosenColor = RA8875_BLUE;
          interface();
          tft.fillRect(10+(40*1)+(10*1),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*2)+(10*2) && tx < 10+(40*3)+(10*2))){
          choosenColor = RA8875_RED;
          interface();
          tft.fillRect(10+(40*2)+(10*2),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*3)+(10*3) && tx < 10+(40*4)+(10*3))){
          choosenColor = RA8875_GREEN;
          interface();
          tft.fillRect(10+(40*3)+(10*3),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*4)+(10*4) && tx < 10+(40*5)+(10*4))){
          choosenColor = RA8875_CYAN;
          interface();
          tft.fillRect(10+(40*4)+(10*4),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*5)+(10*5) && tx < 10+(40*6)+(10*5))){
          choosenColor = RA8875_MAGENTA;
          interface();
          tft.fillRect(10+(40*5)+(10*5),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*6)+(10*6) && tx < 10+(40*7)+(10*6))){
          choosenColor = RA8875_YELLOW;
          interface();
          tft.fillRect(10+(40*6)+(10*6),10,40,40,RA8875_BLACK);
        else if ((tx > 10+(40*7)+(10*7) && tx < 10+(40*8)+(10*7))){
          choosenColor = 0;
          interface();
          tft.fillRect(0,52,tft.width()-1,tft.height()-53,RA8875_BLACK);
          tft.fillCircle(tft.width()-10,10,5,RA8875_BLACK);
      } else { //paint
        //if (choosenColor != 0) tft.fillCircle(tx,ty,1,choosenColor);
        if (choosenColor != 0) tft.drawPixel(tx,ty,choosenColor);
anyone familiar with this screen? Is there something else I should be doing?
Many thanks
Thought I'd leave this here to help any other newbie who might be struggling with this. I'd assumed(always a bad thing) that the touch screen was accessed via the SPI bus, yeah I know, all the clues where there and it's even on Sumotoy's wiki, although it's easy to miss, you need to wire up the interrupt! (pin 10 JP3 on the display) that's why there is a ISR in the library, so a thorough reading of documentation and using some common sense goes a long way.
