Eastron SDM630 with NodeMCU - compile problem
Hi!
Im trying to compile this project but its probably a bit above my level of knowlage :confused:
Link to where I found this code and some explanation of what its for GitHub - peninquen/Modbus-Energy-Monitor-Arduino: A class to collect data from a energy monitor that uses modbus protocol.
If anyone would like to take a look at why this is not compiling I would be most thankful :slight_smile:
I get these faults:
C:\Users\Gerles\AppData\Local\Temp\buildbf57b7c4436269c9ccbd3be80722fdec.tmp\sketch\ModbusSensor.cpp: In member function 'void modbusMaster::begin(uint16_t, uint8_t)':
ModbusSensor.cpp:119: error: invalid conversion from 'uint8_t {aka unsigned char}' to 'SerialConfig' [-fpermissive]
(*_hwSerial).begin(baudrate, byteFormat);
In file included from C:\Users\Gerles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/Arduino.h:246:0,
from C:\Users\Gerles\AppData\Local\Temp\buildbf57b7c4436269c9ccbd3be80722fdec.tmp\sketch\ModbusSensor.h:16,
from C:\Users\Gerles\AppData\Local\Temp\buildbf57b7c4436269c9ccbd3be80722fdec.tmp\sketch\ModbusSensor.cpp:25:
C:\Users\Gerles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\cores\esp8266/HardwareSerial.h:77:10: error: initializing argument 2 of 'void HardwareSerial::begin(long unsigned int, SerialConfig)' [-fpermissive]
void begin(unsigned long baud, SerialConfig config)
C:\Users\Gerles\AppData\Local\Temp\buildbf57b7c4436269c9ccbd3be80722fdec.tmp\sketch\ModbusSensor.cpp: In member function 'boolean modbusMaster::available()':
ModbusSensor.cpp:168: error: 'SERIAL_TX_BUFFER_SIZE' was not declared in this scope
if ((*_hwSerial).availableForWrite() < SERIAL_TX_BUFFER_SIZE - 1) { //TX buffer not empty
Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Gerles\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.2.0\libraries\ESP8266WiFi
Using library pubsubclient-master at version 2.6 in folder: C:\Users\Gerles\Documents\Arduino\libraries\pubsubclient-master
exit status 1
esp8266modbusEnergyMonitor.ino (3.36 KB)
ModbusSensor.cpp (15.4 KB)
ModbusSensor.h (6.15 KB)
SDMdefines.h (2.29 KB)
To make code easier to read....
  ModbusEnergyMonitor example
  An example to collect data from a Modbus energy monitor using ModbusSensor class
  to datalogger, include a RTC DS3231 and a SD card
  version 0.5 BETA 4/01/2016
  Author: Jaime García  @peninquen
  License: Apache License Version 2.0.
#include <ESP8266WiFi.h>      //ESP library from http://github.com/esp8266/Arduino
#include <PubSubClient.h>     // MQTT library from https://github.com/knolleary/pubsubclient
#include "ModbusSensor.h"
#include "SDMdefines.h"
// Update these with values suitable for your network.
const char* ssid = "........";
const char* password = "........";
const char* mqtt_server = "broker.mqtt-dashboard.com";
WiFiClient espClient;
PubSubClient client(espClient);
uint8_t msg[50];
#define MB_SERIAL_PORT &Serial   // ESP8266 has two serial ports, but Serial1 only Tx
// Serial.swap() change pins to Tx and Rx
#define MB_BAUDRATE       2400          // b 2400
#define MB_BYTEFORMAT     SERIAL_8N2    // Prty n
#define TxEnablePin       2
#define ID_1  1                       // id 001  modbus id of the energy monitor
#define REFRESH_INTERVAL  5000        // refresh time, 5 SECONDS
struct three_phase {
  float line3, line2, line1;
} voltage, current, power;
float energy = 0.0;
// global variables to poll, process and send values
//modbusSensor(uint8_t id, uint8_t fc, uint16_t adr, uint8_t hold, uint8_t sizeofValue)
modbusSensor volt(ID_1, VOLTAGE, CHANGE_TO_ZERO, sizeof(three_phase));
modbusSensor curr(ID_1, CURRENT, CHANGE_TO_ZERO, sizeof(three_phase));
modbusSensor pwr(ID_1, POWER, CHANGE_TO_ZERO, sizeof(three_phase));
//modbusSensor(uint8_t uint16_t adr, uint8_t hold)
modbusSensor enrg(ID_1, IAENERGY, HOLD_VALUE);
  pinMode(BUILTIN_LED, OUTPUT);
  setup_wifi();
  client.setServer(mqtt:server,1883);
  client.setCallback(callback);
  MBSerial.config(MB_SERIAL_PORT, TxEnablePin, REFRESH_INTERVAL);
  MBSerial.begin(MB_BAUDRATE, MB_BYTEFORMAT);
  delay(95);
  Serial.println("time(s),Volt1(V), Volt2(V), Volt3(V), Curr1(A) Curr2(A), Curr3(A), Power1(W), Power2(W), Power3(W), Energy(Kwh)");
  if (MBSerial.available()) {
    volt.read(voltage);
    curr.read(current);
    pwr.read(power);
    energy = enrg.read();
    Serial.print(millis() / 1000);
    Serial.print(",");
    Serial.print(voltage.line1, 1);
    Serial.print(",");
    Serial.print(voltage.line2, 1);
    Serial.print(",");
    Serial.print(voltage.line3, 1);
    Serial.print(",");
    Serial.print(current.line1, 2);
    Serial.print(",");
    Serial.print(current.line2, 2);
    Serial.print(",");
    Serial.print(current.line3, 2);
    Serial.print(",");
    Serial.print(power.line1, 2);
    Serial.print(",");
    Serial.print(power.line2, 2);
    Serial.print(",");
    Serial.print(power.line3, 2);
    Serial.print(",");
    Serial.println(energy, 2);
void setup_wifi() {
  delay(10);
  // We start by connecting to a WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    Serial.print(".");
  Serial.println("");
  Serial.println("WiFi connected");
  Serial.println("IP address: ");
Hello! Do you found a solution to this problem?
