Easy and Simple Wireless
Hi
I am not sure where to start so maybe you could help me :slight_smile:
I want to send very simple data between two modules wirelesly. So I would have one transmitter and one receiver.
Based on the data received, the receiver will then have things to do (led, relays, etc.). But how can I send data from one to another very easily.
I could send maybe codes (ex: A1, A2, B1) or just number (1,2,3,4) or binary (0001, 0010, 0011) or other format.
No big chain of data, Unidirectionnal, no big network, internet thing.
Any ideas?
Thanks in advance!!
You forgot what is probably the most vital criterion - the range.
Sorry, about 10ft maximum but it would be around 5ft in general.
These are very cheap and easy to use. 433Mhz trans/receivers
Awesome, I will try these!
Thanks so much!
Would you have a suggestion for something similar but with bigger range (for another project). About 1000ft.
For longer ranges, you would want to use Xbees (expensive), these HERE, can go about 100 meters.
There is also this that can go 1000m or +3000 feet
The NRF24L01 seems to be a very very good option! Lot of range and not expensive!
However, I guess I need 2 because they are transceivers?
Have you worked with these? Is it easy as plugging them into arduino on each side? Just like the 433?
Thanks!
I have not worked with them, only the 433 MHz T&R. But I do believe there is a library you can download if you search "NRF24L01 library".
NRF24L01 are easy to use, but from what I remember they are 3.3V devices, so they need level translation,
http://playground.arduino.cc/InterfacingWithHardware/Nrf24L01
http://fritzing.org/projects/nrf24l01-wireless-module-with-arduino
If you are just doing simple stuff sending in one direction, these 433mhz modules would be fine
http://www.ebay.com/itm/433Mhz-RF-transmitter-receiver-link-kit-for-Arduino-ARM-MC-U-remote-control-/201108260404?pt=LH_DefaultDomain_2&hash=item2ed2fc8634
Use virtual wire to send the data
https://www.pjrc.com/teensy/td_libs_VirtualWire.html
Actually, it looks like virtual wire has now been superseded or renamed to RadioHead (umm not sure there isn't a trademark issue with that :wink:
Anyway the 433mhz modules are easier to wire up and work on 5v, so no level shifting is required
