Easy, cheap and simple modular home automation system
I wanted a way to easily turn lights on and off, have it wireless controlled, have no computer running, and have the price as low as possible.
To accomplish this, I instead used an arduino duemilanove with an ethernet shield and 433 MHz RF sender, it then sends a message to an arduino with a matching receiver, and changes the pin set in the message.
Source codes can be found here: Mikeys Notes
Looks a nano or something in there? That's not a duemilanove.
What's the relay board you are using?
CrossRoads:
And it got no ethernet shield on either, and this isn't the sender.
On the picture you can see the receiver, which is a nano with the 433 MHz receiver module connected.
The relay board is just the cheapest I could find on eBay, it says 1982A on it, but there are a few different versions which all basically do the same. Would be too expensive if I made them myself, and these are even opto isolated from the arduino and with a current limiting resistor on the relay board too.
Very nice! I always cringe when opening home automation related threads on this board for fear of seeing another example where a user has thrown together something with duct tape, inappropriate wiring, no grounding, and tapped it directly into mains voltage.
Was pleasantly surprised to see that this was NOT one of those projects :slight_smile: Nice clean build.
What is the red breakout board in the picture? Power supply?
bld:
buzzdavidson:
Yes, it is a variable switch mode power supply.
The power supply in my garage door opener is driving it, but it is giving out 24V, so I had to use something else than a 7812 :wink:
which power supply is it? I'm always looking for a power supply to run something and this one is small; was it cheap too?
draythomp:
It is one of these http://www.ebay.co.uk/itm/LM2596-DC-DC-Step-Down-Adjustable-Power-Supply-Module-/220810055661?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item33694e0fed#ht_3092wt_932
And it is now put into use in my garage.
For source code, and how to use it, have a look here: Mikeys Notes
That was awesome! I wish the cat has some role in the video or the project :grin:
Hey, he shut the door to keep it out.
Nicely done.
