How would you know? It's only going to flash that LED for a nanosecond or two, then go right back to the first for() loop. Your eyes can't see a nanosecond.
Please use [ code ] tags next time. It's the button on the full editor that looks like </>. If you don't use code tags, the forum software eats some of your code and most forum regulars won't reply to you because they know there might be pieces missing.
How can you tell it's not reaching the if statement?
Your loop() is going to run forever: driving your LED pin high for a while, driving your LED pin low for a while, evaluating the if statement, and then repeating.
If your if statement drives the pin high it's going to do it slightly before your first for loop will the next time loop() runs. I don't see how you could tell that happened.
If your if statement drives the pin low, it's already low from the second for loop which ran immediately before. I don't see how you could tell that happened either.
I am usiing the for loops because later I will try using it in interrupt where delay doesn`t work.
so I just want the LED to flash for about 3 secs , gow low for 3 secs and then I want it to keep flashing for ever untill I push the button and send HIGH to buttonPin 11.
Google ' Arduino Blink Without Delay '
You must master this technique if you plan to learn Arduino programming.
There is an example in the IDE.
Study this sketch:
//Blink without Delay skeleton
//4 examples demonstrated
//LED wiring options
//Depending which way your LEDs are wired, uncomment the next line.
//#define PlusEqualsON
#ifdef PlusEqualsON
//wired so +5V turns LED ON
#define ledON HIGH
#define ledOFF LOW
#else
//wired so +5V turns LED OFF
#define ledON LOW
#define ledOFF HIGH
#endif
//switch wiring options
//Depending which way your switches are wired, uncomment the next line.
#define PushEqualsLOW
#ifdef PushEqualsLOW
//pushing the switch makes pin LOW
#define Pushed LOW
#define Released HIGH
#else
//pushing the switch makes pin HIGH
#define Pushed HIGH
#define Released LOW
#endif
unsigned long currentMillis;
unsigned long pin13Millis;
unsigned long pin12Millis;
unsigned long pin11Millis;
unsigned long SwitchMillis;
//if these are not changed in the sketch, they can be const
unsigned long debounceMillis = 100UL; //100ms
unsigned long ledOnTime = 5*1000UL; //5 seconds
byte laststartSwitchState = HIGH;
byte buttonState = HIGH;
byte counter = 0;
//the following are enable/disable flags
//some of these might not be used in this sketch
boolean flag13 = true;
boolean flag12 = true;
boolean flag11 = true;
boolean flag10 = true;
const byte startSwitch = 2; //pushed = LOW
const byte testSwitch = 3; //pushed = LOW
digitalWrite(13,ledOFF);
pinMode(13, OUTPUT);
digitalWrite(12,ledOFF);
pinMode(12, OUTPUT);
digitalWrite(11,ledOFF);
pinMode(11, OUTPUT);
digitalWrite(10,ledOFF);
pinMode(10, OUTPUT);
pinMode(startSwitch, INPUT_PULLUP); //pushed = LOW
pinMode(testSwitch, INPUT_PULLUP); //pushed = LOW
} // >>>>>>>>>>>>>> E N D O F s e t u p ( ) <<<<<<<<<<<<<<<<<
//save the current time
currentMillis = millis();
//************************************* E x a m p l e 1
//toggle pin 13 every 200mS
//has 200ms or more gone by?
if (currentMillis - pin13Millis >= 200UL)
//code here runs every 200ms
//get ready for next iteration
pin13Millis = pin13Millis + 200UL;
//toggle pin 13
digitalWrite(13,!digitalRead(13));
//************************************* E x a m p l e 2
//at power up, pin 12 LED goes ON, after 3 seconds goes OFF and stays OFF
//could be used as a powerup reset signal
if (flag12 == true && currentMillis - pin12Millis <= 3000UL)
//code here runs for 3 seconds after power up, then stops
digitalWrite(12,ledON);
//disable further pin 12 control
flag12 = false;
//************************************* E x a m p l e 3
//if testSwitch is pushed and released
//pin 11 LED goes ON for 5 seconds, then goes OFF
buttonState = digitalRead(testSwitch);
//are we are allowed to check the switch and is it pressed?
if(flag11 == true && buttonState == Pushed)
//enable timing of LED on pin 11
flag11 = false; //false --> timing is enabled
//turn LED ON
digitalWrite(11,ledON);
//record the time LED turned ON
pin11Millis = currentMillis;
//are we allowed and is it time to control pin 11
if (flag11 == false && currentMillis - pin11Millis >= ledOnTime)
//if enabled, code here runs after ledOnTime ms goes by
//allow switch press detection again
flag11 = true; //true --> switch monitoring is enabled
//************************************* E x a m p l e 4
//is it time to check the switches?
//in particular, pushing startSwitch will turn ON/OFF (toggle) an output pin 10
if (currentMillis - SwitchMillis >= debounceMillis)
//code here runs every debounceMillis ms
//get ready for the next iteration
SwitchMillis += debounceMillis;
//go and check the switches
checkSwitches();
//put other non-blocking stuff here
} // >>>>>>>>>>>>>> E N D O F l o o p ( ) <<<<<<<<<<<<<<<<<
// F U N C T I O N S
//****************** c h e c k S w i t c h e s ( ) *********************
//switches are checked every debounceValue milli seconds
//no minimum switch press time is validated with this code (i.e. No glitch filter)
void checkSwitches()
//re-usable for all the switches
boolean thisState;
//************************************* E x a m p l e Push ON push OFF (toggle)
//check if this switch has changed state
thisState = digitalRead(startSwitch);
if (thisState != laststartSwitchState)
//update the switch state
laststartSwitchState = thisState;
//this switch position has changed so do some stuff
//"HIGH condition code"
//switch went from LOW to HIGH
if(thisState == HIGH)
//Do some HIGH switch stuff here
//"LOW condition code"
//switch went from HIGH to LOW
//Do some LOW switch stuff here
digitalWrite(10, !digitalRead(10));
//print number of pushes
counter++;
Serial.println(counter);
} //END of startSwitch code
//similar code for other switches goes here
} //END of checkSwitches()
// E N D O F C O D E
I see, then in that case you'd want to change the code like this:
int ledPin = 9;
unsigned long b = 0;
unsigned long c = 0;
const int buttonPin = 11;
int buttonState = LOW;
pinMode(ledPin, OUTPUT);
pinMode(buttonPin, INPUT);
if (buttonState == LOW) {
buttonState = digitalRead(buttonPin);
for(b=0; b<300000; b++){
digitalWrite(ledPin, HIGH);
for(c=0; c<300000; c++){
digitalWrite(ledPin,LOW);
else {
digitalWrite(ledPin, LOW);
This will flash your LED until you press the button once, after it will never flash again.
You'd be better off checking out BlinkWithoutDelay and work your button into that example instead, however.
For example, the code I posted here requires you to have the button held in between blinks. It also wastes a ton of the processors time in those for loops. BlinkWithoutDelay solves those problems.
I will drive a motor for half circle (35 seconds) , stop it for 10 seconds and then drive it backwords for about 5 seconds. the problem is that it`s analogue motor and will be accumulating position error(starting position).
so I will drive it backwords till it hits a button (when it hits the button keeps going for half a second to pass it and then reset the program by sending law pulse from a digital pin to the reset pin,because if it stayed on the button it would be resetting for ever). in this way I hope the motor to starts from the same position.
but I am trying with some leds and then I will do it with the motor.
anywahy thank you again.
