Easy code question for an RFID reader.....
Hello,
I have my arduino working fine and outputing a 5 byte code through the serial monitor using the code from…
http://www.arduino.cc/playground/Code/ID12
I would like to write an if statement, that will output for a particular card. Right now upon a card scanned through the com I’m getting “5-byte code: 21 00 72 B7 3F” as I should.
However, I’m looking to add to this code to actually identify cards with a series of if statements. For example, I would like to be able to code something like the following.
if “5-byte code: 21 00 72 B7 3F is read”
Serial.print(“Card 1”)
if “5-byte code: 21 00 34 J3 3G is read”
Searial.print(“Card 2”)
This way I’m identify cards in the serial monitor instead of getting a string. I’m sure you get what I’m trying to get at. If anyone can think of a nice way to do this I appreciate any help.
Thanks in advance…
Sounds like you need to look at something like “memcmp”
The string library at:
http://arduino.cc/en/Tutorial/TextString
may also be of use to you.
Thanks for the prompt responses…
After looking around the forum for a while I think using the strcmp command function should work just fine. I have limited programming knowledge.
Could someone enlighten me on the correct way to go about doing this or why I am getting error: invalid conversion from ‘byte*’ to ‘const char*’
I have only added the define tag and string comparison code.
char tag1[] = "210072B73F"; //define tag 1
  Serial.begin(9600);                                 // connect to the serial port
void loop () {
  byte i = 0;
  byte val = 0;
  byte code[6];
  byte checksum = 0;
  byte bytesread = 0;
  byte tempbyte = 0;
  if(Serial.available() > 0) {
    if((val = Serial.read()) == 2) {                  // check for header
      bytesread = 0;
      while (bytesread < 12) {                        // read 10 digit code + 2 digit checksum
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 0x0D)||(val == 0x0A)||(val == 0x03)||(val == 0x02)) { // if header or stop bytes before the 10 digit reading
            break;                                    // stop reading
          // Do Ascii/Hex conversion:
          if ((val >= '0') && (val <= '9')) {
            val = val - '0';
          } else if ((val >= 'A') && (val <= 'F')) {
            val = 10 + val - 'A';
          // Every two hex-digits, add byte to code:
          if (bytesread & 1 == 1) {
            // make some space for this hex-digit by
            // shifting the previous hex-digit with 4 bits to the left:
            code[bytesread >> 1] = (val | (tempbyte << 4));
            if (bytesread >> 1 != 5) {                // If we're at the checksum byte,
              checksum ^= code[bytesread >> 1];       // Calculate the checksum... (XOR)
            tempbyte = val;                           // Store the first hex digit first...
          bytesread++;                                // ready to read next digit
      // Output to Serial:
      if(bytesread == 12) {         // if 12 digit read is complete
        if(strcmp(code, tag1) == 0) //compare tag1 to the tag read
          Serial.print("Tag 1");
     // if (bytesread == 12) {                          // if 12 digit read is complete
     //   Serial.print("5-byte code: ");
     //   for (i=0; i<5; i++) {
     //      if (code[i] < 16) Serial.print("0");
     //      Serial.print(code[i], HEX);
     //      Serial.print(" ");
        Serial.print("Checksum: ");
        Serial.print(code[5], HEX);
        Serial.println(code[5] == checksum ? " -- passed." : " -- error.");
      bytesread = 0;
Nope. Won't work. There are "embedded nulls" in the ID. strcmp will stop comparing when it reaches them.
AWOL's advice is sound. memcmp is what you need to use.
