Hello.
This is a very "electronics newbie" and simple question.
I need an electronic switch/gate that STAYS CLOSED with a single pulse (digital high pulse), and STAYS OPEN with the next pulse whenever i send it.
Things i know:
Relays will only stay CLOSED while the signal is HIGH. Doesn´t work for me.
Optocouplers/transistors, same thing... maybe i can use an optocoupler to drive the actual pulse if the digital 40mA is not enough.
There MUST be a darn single electronic switch that stays open/close by receiving a single digital HIGH pulse.
Could anyone please recommend one of these?
I need this because i´m controling a heating application. The resistor has to stay ON till the air temperature raises to a certain degree. It´s not a solution to leave the digital pin HIGH driving a relay for 10 minutes. I would like to send a single HIGH to turn it on, and a single HIGH to turn it off.
