Easy IF function and Fail :-(
Hi Guys,
I need some help as I really don't understand what is wrong.
Situation:
Im going to program a arduino for my digital printing press. When toner is empty on the hardware i will activate a signal that is high. From that point on our software starts counting pulses. Until a certain amount of pulses is reached the machine will give a 'toner fill warning'.
My goal is to program the arduino to setup a TV monitor with the toner condition so there is no need to stay near the machine.
The above I wil try to duplicate via 2 push buttons.
Button 1 is the hardware state
Button 2 i use for counting > so every time the button is pushes it will increase a count (not implemented yet)
I started easy to make sure that if button 1 is pushed a red LED goes on > so far so good..
I tried to add the button 2 > if only BOTH are pushed the red LED goes on.
Result: in my programming the RED LED goes already on when only button 1 is pushed and I can't understand what I'm doing wrong.
PLEASE HELP ASAP... :slight_smile:
Code:
int dosLevelSensorButton = 4; //push button for dosLevelsensor
int countPulsesButton = 7; //push button for counting pulses
int ledDosLevel = 8; //LED for DOS level empty
int ledPulses = 2; //LED for puls count
//int countedPulses = 0; //puls counter
int dosLevelState = 0; //state check DOS level sensor
int countPulsState = 0; //state check count puls button
pinMode(dosLevelSensorButton, INPUT);
pinMode(countPulsesButton, INPUT);
pinMode(ledDosLevel, OUTPUT);
pinMode(ledPulses, OUTPUT);
//dosLevelState = digitalRead(dosLevelSensorButton);
//countPulsState = digitalRead(countPulsesButton);
if ((digitalRead(dosLevelState) == HIGH) && (digitalRead(countPulsState) == HIGH)) {
digitalWrite(ledDosLevel, HIGH);
Serial.println("DOS level sensor active");
else { digitalWrite(ledDosLevel, LOW); }
How are the buttons sewn on? Using INPUT_PULLUP makes wiring switches easier, and more reliable.
