Easy programming multiple inputs / outputs
I have a project that uses 21 inputs and 21 outputs. For some debugging I am writing a simple program that give's me the pin number when an attached button is pushed, through the serial.Print fuction. All is working well but it is a lot of copy paste and then changing numbers. Isn't there a more convinient way to do this?
See attached code (I do need to change some numbers for it to work)
Check_pin_number.pde (3.63 KB)
It would have been easier all round if you had posted your code here instead of attaching it. As it is I have not looked at your code but the answer is almost certainly to use an array of pin numbers and a for loop to read the inputs and output the number of the pins when you find a button pressed.
If you used an array of pin numbers and an array of pin states, you'd have a complete program in about 20 lines of code.
