I wrote an easy code in C# that turn led on when pc keyboard key is hold down and turn led off when pc keyboard key is released. When i hold the key, arduino tx and rx leds constant blink, because arduino constantly receives data.
OP probably means it's the onboard LED connected to pin 13 which has a resistor in series. If my assumption is false, take the advise of AWOL literally and disconnect the LED, you may destroy the port of the Arduino.
My question is will i damage the arduino?
No, but why are you doing it this way? Send one value when the key transitions to pressed, and another when the key transitions to released, and nothing in between.
Probably a stupid question but how to program that?
Then disconnect it immediately and put a resistor in series.
In the keyPressed event handler, send the lower case version of the key that triggered the event. In the keyReleased event handler, send the upper case version of the key that triggered the event.
