I'm a newbie to the arduino. I'm working on a project that turns a 18vdc motor on and off with one momentary switch and turn the motor off and turn on a 12vdc light and buzzer with a separate switch. I have been trying to figure out how to wire the motor through a 4 board relay with the switches to the arduino. I haven't found a video or diagram that shows how to wire a motor through a relay using a switch and arduino.
What relay board do you have?
To be clear, you want to control: one motor, a light and a buzzer with an Arduino through a relay board?
Wow. Nice response time LarryD. Appreciate it. The relay is a 4 relay module (amazon link below) and yes sir, pretty much going to push a momentary switch #1 to start the motor and stop the motor, if momentary Switch #2 is pressed while the motor is running then the motor stops and the light and buzzer activate.
What electronics background do you have?
What programming experience do you have?
Thanks LarryD. I pretty much have most of it wired up. I have the momentary switches doing what they are supposed to be doing but they are on a breadboard going to an led. I need to put the relay/ motor in place of the led. The wiring from the breadboard/arduino to the relay/18vdc power supply/motor is what is stumping me. I have never wired a relay before.
How many amps is your motor rate for?
Better still do you have a link to the motor?
See image for motor wiring, ignore numbers on the schematic:
I don't have the specs on the motor but I can see if I can find them. I'm using a 18vdc cordless drill motor from harbor freight.
Arduino to relay PCB:
JD-Vcc jumper installed.
Here's what I'm working with. Btw . I can't thank you enough LarryD. You are the man!
Here's the picture
Where :o
We're like CSI Miami. We never close.
Got it working. LarryD is the man. Now to add lights and buzzer.
Lots of us here ready help as needed, we have a great community.
If you are done is is customary to change your post title to indicate the post is solved by inserting “[SOLVED]” in front of the post title.
ie:
Re: [SOLVED] Easy questions for the experts
Will do raschemmel. Still new to all of this.
I don't see an option to change the topic to solved though
