Easy Shift Register Library
(deleted)
Suggestion: new class name.
Binstop says nothing to me about what the library is - I had to read the comments to understand.
A better name would be something like "shiftreglib" or something similar; something generic enough that it could be expanded in the future to allow for use with other shift-register parts (the 74hc595 is one of many such parts), much like the LCD libraries that exist.
Other than that, I think a library like this has been long overdue, and should be placed in the playground.
(deleted)
sorry but i don't understand the call registerWrite(bitToSet, HIGH);
with this signature void registerWrite(int whichPin, int whichState) {}
bit with pin , and HIGH with int value thanks
(deleted)
ok High is my ignorance of c :), now i undderstand. so... in the example file you call registerWrite(bitToSet, HIGH); bitToSet is a number
in the function registerWrite(int whichPin, int whichState) the number that you pass in, is for wichPin (the number of pin) an not the number to pass througth. why?
OK I UNDERSTAND, sorry for the stupid question
thanks for the library ;)
Nice library, thanks for posting. Your library inspired me to post details on using SPI for really fast shift register control.
You may want to consider SPI either in other projects and/or as an optional feature in your library.
Here is a link to a post I just added that shows how to implement SPI (and seemless PWM control) via 74HC595 shift registers. http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1278251011
I'd be interested in your input as you use may use these more than I do.
