I am running out of time - Please help if you can. P.S. I had problems with the I2C method - I would rather use direct wiring for the controllers.
The code below is for testing the communication only.
Data being sent is Int values between 0 and 99. The data instructs the sub-controllers to run script codes.
My project is using a Mega 2560 as the main controller and three Uno units as Sub-Controllers. Communication is using Easy Transfer with wiring connecting serial pins 1, 2, 3 on the Mega to the three Uno serial pins. I can get the program to work doing only one serial connection at a time - but I need to communicate on all three serial sets at the same time. Here is the TX program - note that I have modified it to use serial 1. What do I need to do to get Serial 2 and Serial 3 to work with Serial 1.
// Program for recieving commands over serial TX RX
#include <EasyTransfer.h>
//create object
EasyTransfer ET;
struct SEND_DATA_STRUCTURE{
//put your variable definitions here for the data you want to send
//THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
int Command;
int pause;
//give a name to the group of data
SEND_DATA_STRUCTURE mydata;
void setup(){
Serial1.begin(9600);
//start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
ET.begin(details(mydata), &Serial1);
pinMode(13, OUTPUT);
void loop(){
//this is how you access the variables. [name of the group].[variable name]
mydata.Command = 10;
mydata.pause = random(5);
//send the data
ET.sendData();
//Just for fun, we will blink it out too
for(int i = mydata.Command; i>0; i--){
digitalWrite(13, HIGH);
delay(mydata.pause * 100);
digitalWrite(13, LOW);
delay(5000);
Here is the RX code - do I need to change something here also to make everything work?
// Program for receiving commands over serial TX RX
//create object
EasyTransfer ET;
struct RECEIVE_DATA_STRUCTURE{
//put your variable definitions here for the data you want to receive
int Command;
int pause;
RECEIVE_DATA_STRUCTURE mydata;
void setup(){
ET.begin(details(mydata), &Serial);
void loop(){
//check and see if a data packet has come in.
if(ET.receiveData()){
//since we have data, we will blink it out.
//you should make this delay shorter then your transmit delay or else messages could be lost
delay(250);
Thank You in advance for your help.
