I am having a problem with my EasyDriver Stepper Motor Driver. I am using a Arduino Mini Pro and this to step a small 12v stepper motor.
Running a 12v 2 amp power supply to the Driver.
The wiring is correct from the Arduino to the Board.
My problem is the Driver board is outputting a constant voltage on the 4 motor pins (pair A and pair B)
This even happens when the EasyDriver Stepper Motor Driver is just disconnected form everything and only is powered with the 12v power. The LED on the board is lighting up as well. (connected to the M= and GND correctly)
Is my board fried? I was under the impression it was not suppose to output constant voltage at any point. Any insight would be greatly appreciated.
Yes, just tie the enable pin to ground. This should shut the motor off.
The motor will get warm / use electricity even if you're not spinning it -- the controller is locking the motor in place so whatever it's connected to can't move.
