EasyDriver Stepper Motor Driver Problem
I am having a problem with my EasyDriver Stepper Motor Driver. I am using a Arduino Mini Pro and this to step a small 12v stepper motor.
Running a 12v 2 amp power supply to the Driver.
The wiring is correct from the Arduino to the Board.
My problem is the Driver board is outputting a constant voltage on the 4 motor pins (pair A and pair B)
This even happens when the EasyDriver Stepper Motor Driver is just disconnected form everything and only is powered with the 12v power. The LED on the board is lighting up as well.
Is my board fried? I was under the impression it was not suppose to output constant voltage at any point. Any insight would be greatly appreciated.
thanks in advance
Please don't post the same thing in multiple places, also known as CrossPosting. If its not the right forum to start, a moderator will move it.
Thanks
Moderator
