Easymesh for ESP8266 callback routines
I have question regarding callback routines. I am using Easymesh.h.
The project is about the communication between two ESP8266. I have made 2 programs one for receiver and one for Transmitter. The Transmitter works fine and I can see the data is getting transferred. But on the receiver side I only get the black screen scrolling down.
So the problem is callback function and the one responsible for receiving data setReceiveCallback()
Keeping the code simple, here is a use
static void (*receivedCallback)( uint32_t ID, String &msgFinal);//FIRST
Setup()
 mesh.setReceiveCallback( &receivedCallback ); //SECOND
loop
  void receivedCallback( uint32_t ID, String &msgFinal);//Third
If I comment out first and second calls the code compiles without error but doesn't work for receiving.
You are defining a function within the loop:
loop
Do it outside of the loop as the example shows.
I even tried to define it outside... Well both compiles without errorr but no-one catches the data..
