EasyNextion writeStr to nextion screen
Hey all,
I am working on a scanner which will save barcodes and the amount of products scanned.
So far I got the code working that it writes the 2 variables on the sd card from my nextion display and my barcode scanner is working on my serial monitor.
The only problem is I want to write the barcode when it scans to a text (t2.txt) on my nextion so it will show you on screen what barcode you have scanned.
the bit of code that isnt working is in the void loop, since I want the scanner to always pick up on new codes that are scanned:
  myNex.NextionListen(); // WARNING: This function must be called repeatedly to response touch events
                         // from Nextion touch panel. Actually, you should place it in your loop function.
  if (Barcode.available()) // Check if there is Incoming Data in the Serial Buffer.
    while (Barcode.available()) // Keep reading Byte by Byte from the Buffer till the Buffer is empty
      char input = Barcode.read(); // Read 1 Byte of data and store it in a character variable
      Serial.print(input); // Print the Byte
      delay(5); // A small delay
    myNex.writeStr("t2.txt");
According to the easynextion github the syntax should work, yet it does not.
Does anyone know what I am doing wrong?
If you need more info I am happy to give that ofcourse.
Greets,
wigets
You have to pass a second parameter which is the actual data
myNex.writeStr("t2.txt", "hello");
so in your case, you will need to put all your barcode data into an array and then pass that along.
    char myBarcode[80];  // large enough for the biggest barcode you will read
    int idx = 0;
      myBarcode[idx++] = input;  // save data
     myBarcode[idx] = '\0';  // terminate string
    myNex.writeStr("t2.txt", myBarcode);
Works like a charm.
Thank you so much for helping a newbie out!
