EasyTransfer arduino Due
Hello,
I install EasyTranfer_2way_wPot_Example and EasyTranfer_2way_wServo_Example on two Arduino due's.
And I use an Half Duplex hardware.
At first I thought it worked well, but sometimes after starting it doesn't go well.
I think I have a situation where both tx (transmit data) of the arduinos are active at the same time.
And that doesn't recover.
Like a response how I can solve this problem.
Or maybe an advice to use another library.
Thanks in advance,
Lenn.
#include <EasyTransfer.h>
EasyTransfer ETin, ETout;
struct RECEIVE_DATA_STRUCTURE{
int16_t buttonstate;
struct SEND_DATA_STRUCTURE{
int16_t servoval;
RECEIVE_DATA_STRUCTURE rxdata;
SEND_DATA_STRUCTURE txdata;
void setup(){
ETin.begin(details(rxdata), &Serial);
ETout.begin(details(txdata), &Serial);
pinMode(13, OUTPUT);
pinMode(12, INPUT_PULLUP);
void loop(){
txdata.servoval = analogRead(0);
if(!digitalRead(12))
txdata.buttonstate = HIGH;
txdata.buttonstate = LOW;
ETout.sendData();
for(int i=0; i<5; i++){
ETin.receiveData();
digitalWrite(13, rxdata.buttonstate);
delay(10);
delay(10);
#include <Servo.h>
//create two objects
Servo myservo;
int16_t servoval;
void setup(){
myservo.attach(9);
void loop(){
ETout.sendData();
ETin.receiveData();
myservo.write(map(rxdata.servoval, 0, 1023, 0, 179));
delay(10);
delay(10);
Read the how to use this forum-please read sticky to see how to properly post code and some advice on how to ask an effective question. Remove useless white space and format the code with the IDE autoformat tool (crtl-t or Tools, Auto Format) before posting code.
