Hi! I have a little problem. I have setup of Fio with Xbee and UNO connected wia serial on one side and the same thing on the other side.
My problem is that without Fios the setup is working right(the servo is changing its angle as the potenciometer is turned) but when I swap the wired serial connection with the Fio with Xbee it is not working.
I have tested the Xbee connection and that looks fine(on two computers with X-CTU they were talking to each other).
On the first UNO there is an example sketch of EasyTransfer
#include <EasyTransfer.h>
//create two objects
EasyTransfer ETin, ETout;
struct RECEIVE_DATA_STRUCTURE{
//put your variable definitions here for the data you want to receive
//THIS MUST BE EXACTLY THE SAME ON THE OTHER ARDUINO
int buttonstate;
struct SEND_DATA_STRUCTURE{
int buttonstate;
int servoval;
//give a name to the group of data
RECEIVE_DATA_STRUCTURE rxdata;
SEND_DATA_STRUCTURE txdata;
void setup(){
//start the library, pass in the data details and the name of the serial port. Can be Serial, Serial1, Serial2, etc.
ETin.begin(details(rxdata), &Serial);
ETout.begin(details(txdata), &Serial);
pinMode(13, OUTPUT);
pinMode(12, INPUT);
//enable pull-up
digitalWrite(12, HIGH);
void loop(){
//first, lets read our potentiometer and button and store it in our data structure
txdata.servoval = analogRead(0);
if(!digitalRead(12))
txdata.buttonstate = HIGH;
txdata.buttonstate = LOW;
//then we will go ahead and send that data out
ETout.sendData();
//there's a loop here so that we run the recieve function more often then the
//transmit function. This is important due to the slight differences in
//the clock speed of different Arduinos. If we didn't do this, messages
//would build up in the buffer and appear to cause a delay.
for(int i=0; i<5; i++){
//remember, you could use an if() here to check for new data, this time it's not needed.
ETin.receiveData();
//set our LED on or off based on what we received from the other Arduino
digitalWrite(13, rxdata.buttonstate);
//delay
delay(10);
//delay for good measure
delay(10);
and on the Fio there is an modified sketch of NewSoftSerial example
#include <NewSoftSerial.h>
NewSoftSerial mySerial(12, 13);
mySerial.begin(9600);
void loop() // run over and over again
if (mySerial.available()) {
Serial.print(mySerial.read());
if (Serial.available()) {
mySerial.print(Serial.read());
on the other side the Fio is the same thing and on the uno is this example code:
#include <Servo.h>
//create servo
Servo myservo;
int buttonstate;
int servoval;
int buttonstate;
void setup(){
pinMode(12, INPUT);
//enable pull-up
myservo.attach(9);
void loop(){
//first, lets read our button and store it in our data structure
ETout.sendData();
ETin.receiveData();
//set our servo position based on what we received from the other Arduino
//we will also map the ADC value to a servo value
myservo.write(map(rxdata.servoval, 0, 1023, 0, 179));
//delay
delay(10);
delay(10);
Can please somebody help me?It is my school project and I am out of mind.I bet that the problem is in the Fio code but where...
