EasyVR 2.0 on YUN
Hi, has anyone ever used before EasyVR 2.0 shield on Arduino YUN ?
I read an old topic where is explained the problems using EasyVR shield on YUN, because it uses serial pin but YUN uses these pins for bridge ... it's true ? I can never use EasyVR shield or it's true only with old EasyVR shield and now with the 2.0 version the problem is resolved ?
Yes, RX and TX are used for Bridge. I think you could use software serial on another pins but I've not seen if the 2.0 changed this.
Thank you for reply .. I will search on internet more information about 2.0 versione. I have just sent an email to the manufacturer asking information about this. I will update in this topic.
mart256:
The same problem I could have also with Arduino Ethernet and/or Arduino Uno + Ethernet Shield ?
I don't know if ethernet shield uses rx tx you should check the shield schematic.
puedo usar arduino uno +ethernet shield +easyvr???
alguien me puede decir?
erickfl18:
Google Translate:
I can use Arduino Uno + ethernet shield + easyvr ???
anyone can tell me?
