EasyVR Shield 2.0 compiling error-need help
I’m using an Arduino mega with the easyvr shield 2.0. The system compiles and loads the TestEasyVr example without errors. However when I try to compile other examples, I get the following error:
Arduino: 1.6.3 (Windows 8.1), Board: “Arduino Mega or Mega 2560, ATmega2560 (Mega 2560)”
treespecies.pde:42:1: error: ‘EasyVRBridge’ does not name a type
treespecies.pde: In function ‘void setup()’:
treespecies.pde:50:7: error: ‘bridge’ was not declared in this scope
Error compiling.
Do you know what is wrong?
This code was auto generated from EasyVR Commander.
#if defined(ARDUINO) && ARDUINO >= 100
#include “Arduino.h”
#include “Platform.h”
#include “SoftwareSerial.h”
#ifndef CDC_ENABLED
// Shield Jumper on SW
SoftwareSerial port(12,13);
#else
// Shield Jumper on HW (for Leonardo)
#define port Serial1
#endif
#else // Arduino 0022 - use modified NewSoftSerial
#include “WProgram.h”
#include “NewSoftSerial.h”
NewSoftSerial port(12,13);
#endif
#include “EasyVR.h”
EasyVR easyvr(port);
//Groups and Commands
enum Groups
GROUP_0 = 0,
GROUP_1 = 1,
enum Group0
G0_DATA = 0,
enum Group1
G1_SUGAR_MAPLE = 0,
G1_ASH = 1,
G1_BASSWOOD = 2,
EasyVRBridge bridge;
int8_t group, idx;
#ifndef CDC_ENABLED
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
Serial.println(“Bridge not started!”);
#else
// bridge mode?
if (bridge.check())
port.begin(9600);
bridge.loop(port);
Serial.println(“Bridge connection aborted!”);
#endif
port.begin(9600);
while (!easyvr.detect())
Serial.println(“EasyVR not detected!”);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println(“EasyVR detected!”);
easyvr.setTimeout(5);
easyvr.setLanguage(0);
group = EasyVR::TRIGGER; //<-- start group (customize)
void action();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
do
// can do some processing while waiting for a spoken command
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
idx = easyvr.getWord();
if (idx >= 0)
// built-in trigger (ROBOT)
// group = GROUP_X; ← jump to another group X
return;
idx = easyvr.getCommand();
if (idx >= 0)
// print debug message
uint8_t train = 0;
char name[32];
Serial.print("Command: “);
Serial.print(idx);
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(” = ");
Serial.println(name);
easyvr.playSound(0, EasyVR::VOL_FULL);
// perform some action
action();
else // errors or timeout
if (easyvr.isTimeout())
Serial.println(“Timed out, try again…”);
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
void action()
switch (group)
case GROUP_0:
switch (idx)
case G0_DATA:
// write your action code here
// group = GROUP_X; ← or jump to another group X for composite commands
case GROUP_1:
switch (idx)
case G1_SUGAR_MAPLE:
case G1_ASH:
case G1_BASSWOOD:
