#if defined(ARDUINO) && ARDUINO >= 100
#include "Arduino.h"
#include "SoftwareSerial.h"
SoftwareSerial port(12,13);
#else // Arduino 0022 - use modified NewSoftSerial
#include "WProgram.h"
#include "NewSoftSerial.h"
NewSoftSerial port(12,13);
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
int8_t set = 0;
int8_t group = 0;
uint32_t mask = 0;
uint8_t train = 0;
char name[32];
bool useCommands = true;
EasyVRBridge bridge;
// bridge mode?
if (bridge.check())
cli();
bridge.loop(0, 1, 12, 13);
// run normally
port.begin(9600);
if (!easyvr.detect())
Serial.println("EasyVR not detected!");
for (;;);
easyvr.setPinOutput(EasyVR::IO1, LOW);
Serial.println("EasyVR detected!");
easyvr.setTimeout(5);
easyvr.setLanguage(EasyVR::ENGLISH);
int16_t count = 0;
Serial.print("Sound table: ");
if (easyvr.dumpSoundTable(name, count))
Serial.println(name);
Serial.print("Sound entries: ");
Serial.println(count);
Serial.println("n/a");
if (easyvr.getGroupMask(mask))
uint32_t msk = mask;
for (group = 0; group <= EasyVR::PASSWORD; ++group, msk >>= 1)
if (!(msk & 1)) continue;
if (group == EasyVR::TRIGGER)
Serial.print("Trigger: ");
else if (group == EasyVR::PASSWORD)
Serial.print("Password: ");
Serial.print("Group ");
Serial.print(group);
Serial.print(": ");
count = easyvr.getCommandCount(group);
for (int8_t idx = 0; idx < count; ++idx)
if (easyvr.dumpCommand(group, idx, name, train))
Serial.print(idx);
Serial.print(" = ");
Serial.print(name);
Serial.print(", Trained ");
Serial.print(train, DEC);
if (!easyvr.isConflict())
Serial.println(" times, OK");
int8_t confl = easyvr.getWord();
if (confl >= 0)
Serial.print(" times, Similar to Word ");
confl = easyvr.getCommand();
Serial.print(" times, Similar to Command ");
Serial.println(confl);
group = 0;
mask |= 1; // force to use trigger
useCommands = (mask != 1);
const char* ws0[] =
"ROBOT",
const char* ws1[] =
"ACTION",
"MOVE",
"TURN",
"RUN",
"LOOK",
"ATTACK",
"STOP",
"HELLO",
const char* ws2[] =
"LEFT",
"RIGHT",
"UP",
"DOWN",
"FORWARD",
"BACKWARD",
const char* ws3[] =
"ZERO",
"ONE",
"TWO",
"THREE",
"FOUR",
"FIVE",
"SIX",
"SEVEN",
"EIGHT",
"NINE",
"TEN",
const char** ws[] = { ws0, ws1, ws2, ws3 };
bool checkMonitorInput()
if (Serial.available() <= 0)
return false;
// check console commands
int16_t rx = Serial.read();
if (rx == 'b')
useCommands = false;
set++;
if (set > 3)
set = 0;
if (rx == 'c')
useCommands = true;
do
group++;
if (group > EasyVR::PASSWORD)
group = 0;
} while (!((mask >> group) & 1));
if (rx == 's')
int16_t num = 0;
delay(5);
while ((rx = Serial.read()) >= 0)
if (isdigit(rx))
num = num * 10 + (rx - '0');
delay(5);
if (rx == '.')
easyvr.stop();
easyvr.playSound(num, EasyVR::VOL_DOUBLE);
if (rx >= 0)
easyvr.stop();
Serial.flush();
return true;
return false;
checkMonitorInput();
easyvr.setPinOutput(EasyVR::IO1, HIGH); // LED on (listening)
if (useCommands)
Serial.print("Say a command in Group ");
Serial.println(group);
easyvr.recognizeCommand(group);
Serial.print("Say a word in Wordset ");
Serial.println(set);
easyvr.recognizeWord(set);
do
if (checkMonitorInput())
return;
while (!easyvr.hasFinished());
easyvr.setPinOutput(EasyVR::IO1, LOW); // LED off
int16_t idx = easyvr.getWord();
if (idx >= 0)
Serial.print("Word: ");
Serial.print(easyvr.getWord());
if (useCommands)
Serial.println(ws[group][idx]);
Serial.println(ws[set][idx]);
// ok, let's try another set
set++;
if (set > 3)
set = 0;
easyvr.playSound(0, EasyVR::VOL_FULL);
idx = easyvr.getCommand();
if (idx >= 0)
Serial.print("Command: ");
Serial.print(easyvr.getCommand());
// ok, let's try another group
do
group++;
group = 0;
else // errors or timeout
if (easyvr.isTimeout())
Serial.println("Timed out, try again...");
int16_t err = easyvr.getError();
if (err >= 0)
Serial.print("Error ");
Serial.println(err, HEX);
Then i go deeper and i checked the EasyVR library file keywords.txt and there is no command as EasyVRBridge, there is only EasyVR. So i changed the EasyVRBridge bridge; to EasyVR bridge; then it starts to throw me errors as:
sketch_nov02b.ino:52:8: error: no matching function for call to 'EasyVR::EasyVR()'
sketch_nov02b.ino:52:8: note: candidates are:
In file included from sketch_nov02b.ino:41:0:
C:\Users\MyPC\Documents\Arduino\libraries\EasyVR-Arduino\src/EasyVR.h:323:3: note: EasyVR::EasyVR(Stream&)
EasyVR(Stream& s) : _s(&s), _value(-1), _group(-1), _id(-1)
C:\Users\MyPC\Documents\Arduino\libraries\EasyVR-Arduino\src/EasyVR.h:323:3: note: candidate expects 1 argument, 0 provided
C:\Users\MyPC\Documents\Arduino\libraries\EasyVR-Arduino\src/EasyVR.h:75:7: note: EasyVR::EasyVR(const EasyVR&)
class EasyVR
C:\Users\MyPC\Documents\Arduino\libraries\EasyVR-Arduino\src/EasyVR.h:75:7: note: candidate expects 1 argument, 0 provided
sketch_nov02b.ino: In function 'void setup()':
sketch_nov02b.ino:57:12: error: 'class EasyVR' has no member named 'check'
sketch_nov02b.ino:60:8: error: 'class EasyVR' has no member named 'loop'
Error compiling.
