I have the EasyVR3 module mounted on it's shield. I've got that stacked on the DUE and the jumper is set to HW(as is advised for the DUE, uses pins 0 and 1). I'm following the user manual but as it instructs on page 22, after I upload this EasyVR Tester over the native USB and view serial monitor, before I can even send the '?' it returns "EasyVR not detected!"(as per line 118 of the code) and prints it over and over in intervals of a few seconds. The LED on the module is lit, indicating that the shield is making good contact. Using Arduino 1.8.1.
Thanks for the help.
#include "Arduino.h"
#if !defined(SERIAL_PORT_MONITOR)
#error "Arduino version not supported. Please update your IDE to the latest version."
#endif
#if defined(SERIAL_PORT_USBVIRTUAL)
// Shield Jumper on HW (for Leonardo and Due)
#define port SERIAL_PORT_HARDWARE
#define pcSerial SERIAL_PORT_USBVIRTUAL
#else
// Shield Jumper on SW (using pins 12/13 or 8/9 as RX/TX)
#include "SoftwareSerial.h"
SoftwareSerial port(12, 13);
#define pcSerial SERIAL_PORT_MONITOR
#endif
#include "EasyVR.h"
EasyVR easyvr(port);
int8_t bits = 4;
int8_t set = 0;
int8_t group = 0;
uint32_t mask = 0;
uint8_t train = 0;
uint8_t grammars = 0;
int8_t lang = 0;
char name[33];
bool useCommands = true;
bool useTokens = false;
bool isSleeping = false;
// setup PC serial port
pcSerial.begin(9600);
// bridge mode?
int mode = easyvr.bridgeRequested(pcSerial);
switch (mode)
case EasyVR::BRIDGE_NONE:
// setup EasyVR serial port
port.begin(9600);
// run normally
pcSerial.println(F("---"));
pcSerial.println(F("Bridge not started!"));
case EasyVR::BRIDGE_NORMAL:
// setup EasyVR serial port (low speed)
port.begin(9600);
// soft-connect the two serial ports (PC and EasyVR)
easyvr.bridgeLoop(pcSerial);
// resume normally if aborted
pcSerial.println(F("Bridge connection aborted!"));
case EasyVR::BRIDGE_BOOT:
// setup EasyVR serial port (high speed)
port.begin(115200);
// initialize EasyVR
while (!easyvr.detect())
pcSerial.println(F("EasyVR not detected!"));
There wasn't enough room for the full code but it's just the standard example provided called "TestEasyVR".
