I put together the (very common) led cube kit from Ebay/ Amazon, and I want to connect it to run on the Arduino. I know about the Github for programming the STC but it's not working for me. I don't understand the code on the STC to program my own animations, but I understand the Arduino code from CHR's instructable.
I've searched everywhere to find out how to connect the Arduino, and found one thing:
But I'm new to all of this, and I'm not sure if I'm reading the schematic correctly. It doesn't seem to match the picture.
1.) Should I just follow the schematic when connecting the wires and use the Arduino? Is there anyone that understands where the wires are going?
2.) Is there any other way I could make this work?
I've just had a quick look at the link you supplied.
There appears to be a good correspondence between the picture and the schematic.
The 74138 is turned through 180 degrees and shunted down 1 pin in the picture. In the schematic, the ordering of the pins on the 74138 is not the same as the physical layout. If you do this project, make a sketch showing the adapter plate in place of the STC chip and all the connections in a physical layout form before you start. The 74138 is required because the Arduino does not have enough pins.
He didn't explain very well why you have to swap out the 8 latch chips for sn74hc574 chips, but anyway these aren't expensive.
He talks about using a 'spare' analog pin for sound, but according to the schematic, there is no spare since he is using all 6 analog output pins. Pin 11 appears to be the only unused pin, so I guess he made a later change.
I wired everything up, I wasn't sure about it so I just winged it . It's actually running, but not correctly. For animations where the LEDs should be lighting individually, the whole row is lighting. But it's working so now I can go back in with more confidence and try again.
My issue is that I can't really tell where the white wires are going in his picture, when they cross, my eyes play tricks on me. Those are the wires I was asking about in my initial question, not the ones going to the Arduino.
