Ebyte E220 problem
I have tried configuring my 2x E220 LoRa to make: one transmitter and the other a receiver. I was met with an error:
Save mode returned not recognized!
11
I'm following LoRa E220 LLCC68 devices – Renzo Mischianti tutorial and wiring diagrams . I checked numerous times the connections retried them didn't change anything with Arduino Uno.
I have also tried setting it up with esp32 and I was greeted with a: Guru Meditation Error: Core 1 panic'ed. I googled it and its due to some "illegal string" but it was the same code as Arduino, pins changed.
My modules are working with the Ebyte software.
If someone could help me, please reach out to me.
Gmail: barkodukinis@gmail.com
Thanks in advance.
not seen your problems!
I have used the Ebyte E220 Point-to-point communication with ESP32 and a STM32 Nucleo-LO73RZ
mainly working from https://www.ebyte-lora-e220-llcc68-device-for-arduino-esp32-or-esp8266-specs-and-basic-use-1
Could you send me how you wired the esp32 ? and maybe you changed the code a bit (for configuration)? I'm using esp32 wroom 32D if it make a difference
the ESP32 wiring was described in the code in post problem-sending-a-double-over-softwareserial-communication-using-ebyte220-900td-lora-modules, e.g.
// E220 pin 1 M0  to ESP32 GND
// E220 pin 2 M1  to ESP32 GND
// E220 pin 3 RXD to ESP32 GPIO16 pullup to 3.3V
// E220 pin 4 TXD to ESP32 GPIO15 pullup to 3.3V
// E220 pin 5 AUX no connection
// E220 pin 6 VCC to ESP32 3.3V
// E220 pin 7 GND to ESP32 GND
connecting my esp32 to this diagram
Screenshot 2023-04-09 113401
I get this error:
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x4000c29b PS : 0x00060530 A0 : 0x800d0d35 A1 : 0x3ffb1f40
A2 : 0x3ffb1f75 A3 : 0x00000000 A4 : 0x0000000b A5 : 0x3ffb1f75
A6 : 0x00002580 A7 : 0x0800001c A8 : 0x00000000 A9 : 0x3ffb1ef0
A10 : 0x00000000 A11 : 0x00000003 A12 : 0x0800001c A13 : 0x00000010
A14 : 0x00000010 A15 : 0x00000000 SAR : 0x0000000a EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x4000c29b:0x3ffb1f40 0x400d0d32:0x3ffb1f50 0x400d2596:0x3ffb1fb0 0x40086189:0x3ffb1fd0
Rebooting...
connecting to your diagram I get:
No response from device! (Check wiring)
12
11
12
in configuration code:
LoRa_E220 e220ttl(&Serial2, 15, 21, 19); // RX AUX M0 M1 what should i change here ?
which program from which library are you running
my tests were in the main simple peer-to-peer LoRa communications with M0 and M1 set to 0
Renzo Mischianti library E220 something and in example code: set_configuration. Could you provide your code and library if you are not using the same ? I would be very grateful. Thanks.
loaded EByte_LoRa_E220_library
and ran File>Examples>Ebyte LoRa E220 Library>01_getConfiguration
Serial Monitor displays
ets Jun  8 2016 00:22:57
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
configsip: �ets Jun  8 2016 00:22:57
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:1
load:0x3fff0030,len:1344
load:0x40078000,len:13836
load:0x40080400,len:3608
entry 0x400805f0
the wiring instructions at the top of the program indicate AUX should be connected to ESP32 GPIO18
but the LoRa_E220 e220tt sets AUX to pin 15
// ---------- esp32 pins --------------
if I change the LoRa_E220 e220tt setting to
LoRa_E220 e220ttl(&Serial2, 18, 21, 19); //  RX AUX M0 M1
and run it the serial monitor displays
Success
1
HEAD : C1 0 8
AddH : 0
AddL : 0
Chan : 15 -> 425MHz
SpeedParityBit     : 0 -> 8N1 (Default)
SpeedUARTDatte     : 11 -> 9600bps (default)
SpeedAirDataRate   : 10 -> 2.4kbps (default)
OptionSubPacketSett: 0 -> 200bytes (default)
OptionTranPower    : 0 -> 22dBm (Default)
OptionRSSIAmbientNo: 0 -> Disabled (default)
TransModeWORPeriod : 11 -> 2000ms (default)
TransModeEnableLBT : 0 -> Disabled (default)
TransModeEnableRSSI: 0 -> Disabled (default)
TransModeFixedTrans: 0 -> Transparent transmission (default)
Success
1
HEAD: C1 8 3
Model no.: 20
Version  : B
Features : 16
Wired LoRa_E220 e220ttl(&Serial2, 18, 21, 19);
Serial2 tried with pin 16 and 17.
with pin: 17
Data size not match!
7
11
7
with pin: 16
7
11
12
I wired RX AUX M0 M1 .
And try to explain to me more step by step if you can because I'm a total begginer to coding and electronics .
Happy Easter .
my ESP32 to E220 wiring was
* E220	      ----- esp32
 * M0         ----- 19
 * M1         ----- 21
 * TX         ----- 17 TX2
 * RX         ----- 16 RX2
 * AUX        ----- 18
 * VCC        ----- 3.3v
 * GND        ----- GND
program
// ESP32_01_getConfiguration  set board as a ESP32 Dev module
// EByte_LoRa_E220_Series_Library program File>Examples>Ebyte LoRa E220 Library>01_getConfiguration
 * LoRa E220
 * Get configuration.
 * You must uncommend the correct constructor.
 * by Renzo Mischianti <https://www.mischianti.org>
 * https://www.mischianti.org
 * E220		  ----- WeMos D1 mini	----- esp32			----- Arduino Nano 33 IoT	----- Arduino MKR	----- Raspberry Pi Pico   ----- stm32               ----- ArduinoUNO
 * M0         ----- D7 (or 3.3v)	----- 19 (or 3.3v)	----- 4 (or 3.3v)			----- 2 (or 3.3v)	----- 10 (or 3.3v)	      ----- PB0 (or 3.3v)       ----- 7 Volt div (or 3.3v)
 * M1         ----- D6 (or 3.3v)	----- 21 (or 3.3v)	----- 6 (or 3.3v)			----- 4 (or 3.3v)	----- 11 (or 3.3v)	      ----- PB10 (or 3.3v)      ----- 6 Volt div (or 3.3v)
 * TX         ----- D3 (PullUP)		----- TX2 (PullUP)	----- TX1 (PullUP)			----- 14 (PullUP)	----- 8 (PullUP)	      ----- PA2 TX2 (PullUP)    ----- 4 (PullUP)
 * RX         ----- D4 (PullUP)		----- RX2 (PullUP)	----- RX1 (PullUP)			----- 13 (PullUP)	----- 9 (PullUP)	      ----- PA3 RX2 (PullUP)    ----- 5 Volt div (PullUP)
 * AUX        ----- D5 (PullUP)		----- 18  (PullUP)	----- 2  (PullUP)			----- 0  (PullUP)	----- 2  (PullUP)	      ----- PA0  (PullUP)       ----- 3 (PullUP)
 * VCC        ----- 3.3v/5v			----- 3.3v/5v		----- 3.3v/5v				----- 3.3v/5v		----- 3.3v/5v		      ----- 3.3v/5v             ----- 3.3v/5v
 * GND        ----- GND				----- GND			----- GND					----- GND			----- GND			      ----- GND                 ----- GND
#include "Arduino.h"
#include "LoRa_E220.h"
// ---------- esp8266 pins --------------
//LoRa_E220 e220ttl(RX, TX, AUX, M0, M1);  // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
// ESP8266 NodeMCU 1.0 (ESP-12E)
// LoRa_E220 e220ttl(D3, D4, D5, D7, D6); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX AUX M0 M1
//LoRa_E220 e220ttl(D2, D3); // Config without connect AUX and M0 M1
//#include <SoftwareSerial.h>
//SoftwareSerial mySerial(D2, D3); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
//LoRa_E220 e220ttl(&mySerial, D5, D7, D6); // AUX M0 M1
// ---------- Arduino pins --------------
//LoRa_E220 e220ttl(4, 5, 3, 7, 6); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX AUX M0 M1
//LoRa_E220 e220ttl(4, 5); // Config without connect AUX and M0 M1
//SoftwareSerial mySerial(4, 5); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX
//LoRa_E220 e220ttl(&mySerial, 3, 7, 6); // AUX M0 M1
// ------------- Arduino Nano 33 IoT -------------
// LoRa_E220 e220ttl(&Serial1, 2, 4, 6); //  RX AUX M0 M1
// ------------- Arduino MKR WiFi 1010 -------------
// LoRa_E220 e220ttl(&Serial1, 0, 2, 4); //  RX AUX M0 M1
 //LoRa_E220 e220ttl(&Serial2, 15, 21, 19); //  RX AUX M0 M1
 LoRa_E220 e220ttl(&Serial2, 18, 21, 19); //  RX AUX M0 M1 <<<<<<<<<<< pin 18
//LoRa_E220 e220ttl(&Serial2, 22, 4, 18, 21, 19, UART_BPS_RATE_9600); //  esp32 RX <-- e220 TX, esp32 TX --> e220 RX AUX M0 M1
// ---------- Raspberry PI Pico pins --------------
// LoRa_E220 e220ttl(&Serial2, 2, 10, 11); //  RX AUX M0 M1
// ---------------- STM32 --------------------
//HardwareSerial Serial2(USART2);   // PA3  (RX)  PA2  (TX)
//LoRa_E220 e220ttl(&Serial2, PA0, PB0, PB10); //  RX AUX M0 M1
void printParameters(struct Configuration configuration);
void printModuleInformation(struct ModuleInformation moduleInformation);
	while(!Serial){};
	// Startup all pins and UART
	e220ttl.begin();
	ResponseStructContainer c;
	c = e220ttl.getConfiguration();
	// It's important get configuration pointer before all other operation
	Configuration configuration = *(Configuration*) c.data;
	Serial.println(c.status.getResponseDescription());
	Serial.println(c.status.code);
	printParameters(configuration);
	ResponseStructContainer cMi;
	cMi = e220ttl.getModuleInformation();
	// It's important get information pointer before all other operation
	ModuleInformation mi = *(ModuleInformation*)cMi.data;
	Serial.println(cMi.status.getResponseDescription());
	Serial.println(cMi.status.code);
	printModuleInformation(mi);
	c.close();
	cMi.close();
void printParameters(struct Configuration configuration) {
	Serial.println("----------------------------------------");
	Serial.print(F("HEAD : "));  Serial.print(configuration.COMMAND, HEX);Serial.print(" ");Serial.print(configuration.STARTING_ADDRESS, HEX);Serial.print(" ");Serial.println(configuration.LENGHT, HEX);
	Serial.println(F(" "));
	Serial.print(F("AddH : "));  Serial.println(configuration.ADDH, HEX);
	Serial.print(F("AddL : "));  Serial.println(configuration.ADDL, HEX);
	Serial.print(F("Chan : "));  Serial.print(configuration.CHAN, DEC); Serial.print(" -> "); Serial.println(configuration.getChannelDescription());
	Serial.print(F("SpeedParityBit     : "));  Serial.print(configuration.SPED.uartParity, BIN);Serial.print(" -> "); Serial.println(configuration.SPED.getUARTParityDescription());
	Serial.print(F("SpeedUARTDatte     : "));  Serial.print(configuration.SPED.uartBaudRate, BIN);Serial.print(" -> "); Serial.println(configuration.SPED.getUARTBaudRateDescription());
	Serial.print(F("SpeedAirDataRate   : "));  Serial.print(configuration.SPED.airDataRate, BIN);Serial.print(" -> "); Serial.println(configuration.SPED.getAirDataRateDescription());
	Serial.print(F("OptionSubPacketSett: "));  Serial.print(configuration.OPTION.subPacketSetting, BIN);Serial.print(" -> "); Serial.println(configuration.OPTION.getSubPacketSetting());
	Serial.print(F("OptionTranPower    : "));  Serial.print(configuration.OPTION.transmissionPower, BIN);Serial.print(" -> "); Serial.println(configuration.OPTION.getTransmissionPowerDescription());
	Serial.print(F("OptionRSSIAmbientNo: "));  Serial.print(configuration.OPTION.RSSIAmbientNoise, BIN);Serial.print(" -> "); Serial.println(configuration.OPTION.getRSSIAmbientNoiseEnable());
	Serial.print(F("TransModeWORPeriod : "));  Serial.print(configuration.TRANSMISSION_MODE.WORPeriod, BIN);Serial.print(" -> "); Serial.println(configuration.TRANSMISSION_MODE.getWORPeriodByParamsDescription());
	Serial.print(F("TransModeEnableLBT : "));  Serial.print(configuration.TRANSMISSION_MODE.enableLBT, BIN);Serial.print(" -> "); Serial.println(configuration.TRANSMISSION_MODE.getLBTEnableByteDescription());
	Serial.print(F("TransModeEnableRSSI: "));  Serial.print(configuration.TRANSMISSION_MODE.enableRSSI, BIN);Serial.print(" -> "); Serial.println(configuration.TRANSMISSION_MODE.getRSSIEnableByteDescription());
	Serial.print(F("TransModeFixedTrans: "));  Serial.print(configuration.TRANSMISSION_MODE.fixedTransmission, BIN);Serial.print(" -> "); Serial.println(configuration.TRANSMISSION_MODE.getFixedTransmissionDescription());
void printModuleInformation(struct ModuleInformation moduleInformation) {
	Serial.print(F("HEAD: "));  Serial.print(moduleInformation.COMMAND, HEX);Serial.print(" ");Serial.print(moduleInformation.STARTING_ADDRESS, HEX);Serial.print(" ");Serial.println(moduleInformation.LENGHT, DEC);
	Serial.print(F("Model no.: "));  Serial.println(moduleInformation.model, HEX);
	Serial.print(F("Version  : "));  Serial.println(moduleInformation.version, HEX);
	Serial.print(F("Features : "));  Serial.println(moduleInformation.features, HEX);
a run gives on serial monitor
Success
1
HEAD : C1 0 8
AddH : 0
AddL : 0
Chan : 15 -> 425MHz
Success
1
HEAD: C1 8 3
Model no.: 20
Version  : B
Features : 16
ran your code connected as you did no pullup pins got this:
TransModeFixedTrans: 1 -> Fixed transmission (first three bytes can be used as high/low address and channel)
12
HEAD: 46 69 120
Model no.: 65
Version : 64
Features : 20
I still get errors but the freq. is changed :confused: .
reversed tx rx pins just in case and got this:
HEAD : 0 0 1
AddH : F0
AddL : 0
Chan : 190 -> 600MHz
OptionSubPacketSett: 10 -> 64bytes
OptionRSSIAmbientNo: 1 -> Enabled
TransModeWORPeriod : 10 -> 1500ms
7
HEAD: 80 0 255
Model no.: 1
Version : 0
Features : 20
do you have esp to arduino transmit recieve code ? Maybe it would work because the freq is changed . Should i try reset the config with the Ebyte program set some channel and try it with Software serial . would i be possibkle to send ~6 variables .
Got it working to transmit a message.
How Could I send more than 1 variable ? maybe in the range of 5 variables ?
And read what you got into variables to print on lcd or something
what program are you using to transmit/receive the data?
upload it using code tags?
I figured it out , Thanks for previuos help how can I maybe honor you and close the forum ?
I encountered more problems . In Renzo's post it isn't clear how could I send fixed structured data i want to send variables and decode them properly in the receiving end . Sending transparent the data is not decoded properly so sometimes I get temp readings as humidity sometimes temp as temp and its inconsistent . Maybe you figured it out ? Thanks .
can you upload the transmitter and receiver code you are using?
the simple: (not structured)
Esp32 receiver
 * EBYTE LoRa E220
 * Receive messages on CHANNEL 23
 * Uncomment #define ENABLE_RSSI true in this sketch
 * if the sender send RSSI also
 * M0         ----- D7 (or GND) 	----- 19 (or GND) 	----- 4 (or GND) 			----- 2 (or GND) 	----- 10 (or GND)	      ----- PB0 (or GND)        ----- 7 Volt div (or GND)
 * M1         ----- D6 (or GND) 	----- 21 (or GND) 	----- 6 (or GND) 			----- 4 (or GND) 	----- 11 (or GND)	      ----- PB10 (or GND)       ----- 6 Volt div (or GND)
// If you want use RSSI uncomment
//LoRa_E220 e220ttl(D3, D4, D5, D7, D6); // Arduino RX <-- e220 TX, Arduino TX --> e220 RX AUX M0 M1
// LoRa_E220 e220ttl(&Serial2, 15, 21, 19); //  RX AUX M0 M1
int period = 5000;
unsigned long time_now = 0;
  e220ttl.begin();
  Serial.println("Start receiving!");
	// If something available
  if (e220ttl.available()>1) {
	  Serial.println("Message received!");
	  // read the String message
#ifdef ENABLE_RSSI
	ResponseContainer rc = e220ttl.receiveMessageRSSI();
  ResponseContainer rc2 = e220ttl.receiveMessageRSSI();
  ResponseContainer rc3 = e220ttl.receiveMessageRSSI();
#else
	ResponseContainer rc = e220ttl.receiveMessage();
  ResponseContainer rc2 = e220ttl.receiveMessage();
  ResponseContainer rc3 = e220ttl.receiveMessage();
#endif
	// Is something goes wrong print error
	if (rc.status.code!=1){
		Serial.println(rc.status.getResponseDescription());
    Serial.println(rc2.status.getResponseDescription());
    Serial.println(rc3.status.getResponseDescription());
	}else{
		// Print the data received
     Serial.println(rc.data);
    Serial.println(rc2.data);
    Serial.println(rc3.data);
#ifdef ENABLE_RSSI
		Serial.print("RSSI: "); Serial.println(rc.rssi, DEC);
#endif
Arduino UNO Transmitter:
 * EBYTE LoRa E220
 * send a transparent message, you must check that the transmitter and receiver have the same
 * CHANNEL ADDL and ADDH
 * Pay attention e220 support RSSI, if you want use that functionality you must enable RSSI on configuration
 * configuration.TRANSMISSION_MODE.enableRSSI = RSSI_ENABLED;
 * and uncomment #define ENABLE_RSSI true in this sketch
#include "DHT.h"
#define DHTPIN 2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
#include <Wire.h>
#include <Adafruit_BMP085.h>
Adafruit_BMP085 bmp;
  dht.begin();
  e220ttl.begin();
  bmp.begin();
//  If you have ever change configuration you must restore It
  Serial.println("Hi, I'm going to send message!");
  // Send message
	float t = dht.readTemperature();
  float h = dht.readHumidity();
  float p = bmp.readPressure() / 100;
 String myPre;
 String myTemp;
 String myHum;
 myPre=String(p);
 myTemp=String(t);
 myHum=String(h);
 delay(5000);
  ResponseStatus rs = e220ttl.sendMessage(myTemp);
  ResponseStatus rs2 = e220ttl.sendMessage(myHum);
  ResponseStatus rs3 = e220ttl.sendMessage(myPre);
  // Check If there is some problem of succesfully send
  Serial.println(rs.getResponseDescription());
#ifdef ENABLE_RSSI
#else
#endif
	}else{
#ifdef ENABLE_RSSI
#endif
  if (Serial.available()) {
	  String input = Serial.readString();
	  e220ttl.sendMessage(input);
Would you be able to help me ?
I think it needs to send first digit for example 1 then the receiver will know its temp etc but I don't know how to do it .
