EC Probe, short-circuit?
I'm developing an EC probe for Arduino to measure the conductivity of water. I created this code and wiring to do the task and still avoid electrolysis (by switching polarity's). Only question is: Would this create a short-circuit, and would it work?
Thanks in advance!
int inputPin = A0;
int inputPin2 = A1;
int power = 3;
int power2 = 2;
const float closedVoltage = 5.00;                //assumed value of voltage (replace with vcc)
const float closedVoltage2 = 5.00;
const float voltageRange = closedVoltage/1024;   //Used to map the analog reading to the voltage of the circuit.
const float voltageRange2 = closedVoltage/1024;
const float resistor = 1000.00;
const float resistor2 = 1000.00;  //size of resistor on the ground line
int conductReading = 0;
int conductReading2 = 0;  //reading from A0 pin
float conductVoltage = 0.00;
float conductVoltage2 = 0.00; //calculated voltage from reading
float resistance = 0.00;   //calculated resistance of water (ohms)
float resistance2 = 0.00;
float area = 0.0002;//area of the all four sides of the electrodes in square meters
float length = 0.01;//distance between the electrodes in meters
float resistivity = 0.0;
float resistivity2 = 0.0; //resistivity of fluid
float conductivity = 0.00;                  //calculated conductivity of water (micro-siemens/m)
float conductivity2 = 0.00;
void setup(){
 pinMode(power, OUTPUT);
 pinMode(power2, OUTPUT);
 pinMode(inputPin, INPUT);
void loop(){
 digitalWrite(power, HIGH);
 digitalWrite(power2, LOW);
 delay(250);
 digitalWrite(power, LOW);
 delay(250);
 digitalWrite(power2, HIGH);
 delay(250);
 delay(250);
 conductReading = analogRead(inputPin);
 conductReading2 = analogRead(inputPin2);
 conductVoltage = conductReading * voltageRange;
 conductVoltage2 = conductReading2 * voltageRange2;
  resistance = ((closedVoltage * resistor)/conductVoltage) - resistor;
  resistance2 = ((closedVoltage2 * resistor2)/conductVoltage2) - resistor2;
 resistivity = resistance * area / length;
 resistivity2 = resistance2 * area / length;
 conductivity = (1 / resistivity)*1000;
 conductivity2 = (1 / resistivity2)*1000;
Serial.print(conductReading);
Serial.print(", Conductivity (milliSiemens/m) =");
Serial.println(conductivity);
Serial.print(conductReading2);
Serial.print(", Conductivity (switch) (milliSiemens/m) =");
Serial.println(conductivity2);
 //delay(1000);
My wiring is attached below:
|500x437
I don't understand the 4 wires to your electrodes and the ground connections. It DOES look like you've shorted the I/O outputs to ground.
If you want to reverse direction, current can flow safely from one output to another as long as there's resistance to limit the current. This is called a "bridge circuit". That means there should be no direct ground connection to the load. The "ground" is created by whichever I/O pin is low at the moment.
Thank you, changed it, removed the grounds, would this avoid a short-circuit?
int inputPin = A0;
int inputPin2 = A1;
int power = 3;
int power2 = 2;
void setup(){
void loop(){
 delay(250);
 delay(250);
 delay(250);
 delay(250);
 //delay(1000);
|500x437
