For 3 weeks I worked on a patient simulator that generates a virtual ECG signal according to BPM (I set them with a potentiometer). The problem I have at the moment is with the signal display, when I enter the serial plotter I get a signal that I don't know where it comes from, even when I disconnect the wires and potentiometer it remains the same and I don't know how I can make it generate my ECG signal.
For this project I use:
-Arduino Nano
-Potentiometer 5k
-20Mhz crystal
-2 resistors of 10K and one of 10 ohms
-16x2 LCD with I2C
I think the problem is a Software problem (which is not my strong point).
I mention that the code is not created by me but taken and modified according to what I have.
The original code can be found here: ecg_simulator/ECG_Simulator.ino at master · lynchzilla/ecg_simulator · GitHub
Below is the code and a video of the signal the Arduino returns to me.
#include <Wire.h>
// various constants used by the waveform generator
#define INIT 0
#define IDLE 1
#define QRS 2
#define FOUR 4
#define THREE 3
#define TWO 2
#define ONE 1
// y_data[543] - digitized ecg waveform, sampled at 1.0 msec
// Waveform is scaled for a 12-bit D/A converter (0 .. 4096)
// A 60 beat/min ECG would require this waveform (543 samples) plus 457 samples
// of the first y_data[0] value of 936.
const short y_data[] = {
939, 940, 941, 942, 944, 945, 946, 947, 951, 956,
962, 967, 973, 978, 983, 989, 994, 1000, 1005, 1015,
1024, 1034, 1043, 1053, 1062, 1075, 1087, 1100, 1112, 1121,
1126, 1131, 1136, 1141, 1146, 1151, 1156, 1164, 1172, 1179,
1187, 1194, 1202, 1209, 1216, 1222, 1229, 1235, 1241, 1248,
1254, 1260, 1264, 1268, 1271, 1275, 1279, 1283, 1287, 1286,
1284, 1281, 1279, 1276, 1274, 1271, 1268, 1266, 1263, 1261,
1258, 1256, 1253, 1251, 1246, 1242, 1237, 1232, 1227, 1222,
1218, 1215, 1211, 1207, 1203, 1199, 1195, 1191, 1184, 1178,
1171, 1165, 1159, 1152, 1146, 1141, 1136, 1130, 1125, 1120,
1115, 1110, 1103, 1096, 1088, 1080, 1073, 1065, 1057, 1049,
1040, 1030, 1021, 1012, 1004, 995, 987, 982, 978, 974,
970, 966, 963, 959, 955, 952, 949, 945, 942, 939,
938, 939, 940, 941, 943, 944, 945, 946, 946, 946,
946, 946, 946, 946, 946, 947, 950, 952, 954, 956,
958, 960, 962, 964, 965, 965, 965, 965, 965, 965,
963, 960, 957, 954, 951, 947, 944, 941, 938, 932,
926, 920, 913, 907, 901, 894, 885, 865, 820, 733,
606, 555, 507, 632, 697, 752, 807, 896, 977, 1023,
1069, 1127, 1237, 1347, 1457, 2085, 2246, 2474, 2549, 2595,
2641, 2695, 3083, 3135, 3187, 3217, 3315, 3403, 3492, 3581,
3804, 3847, 3890, 3798, 3443, 3453, 3297, 3053, 2819, 2810,
2225, 2258, 1892, 1734, 1625, 998, 903, 355, 376, 203,
30, 33, 61, 90, 119, 160, 238, 275, 292, 309,
325, 343, 371, 399, 429, 484, 542, 602, 652, 703,
758, 802, 838, 856, 875, 895, 917, 938, 967, 1016,
1035, 1041, 1047, 1054, 1060, 1066, 1066, 1064, 1061, 1058,
1056, 1053, 1051, 1048, 1046, 1043, 1041, 1038, 1035, 1033,
1030, 1028, 1025, 1022, 1019, 1017, 1014, 1011, 1008, 1006,
1003, 1001, 999, 998, 996, 994, 993, 991, 990, 988,
986, 985, 983, 981, 978, 976, 973, 971, 968, 966,
963, 963, 963, 963, 963, 963, 963, 963, 963, 963,
964, 965, 966, 967, 968, 969, 970, 971, 972, 974,
976, 978, 980, 983, 985, 987, 989, 991, 993, 995,
997, 999, 1002, 1006, 1011, 1015, 1019, 1023, 1028, 1032,
1036, 1040, 1045, 1050, 1055, 1059, 1064, 1069, 1076, 1082,
1088, 1095, 1101, 1107, 1114, 1120, 1126, 1132, 1141, 1149,
1158, 1166, 1173, 1178, 1183, 1188, 1193, 1198, 1203, 1208,
1214, 1221, 1227, 1233, 1240, 1246, 1250, 1254, 1259, 1263,
1269, 1278, 1286, 1294, 1303, 1309, 1315, 1322, 1328, 1334,
1341, 1343, 1345, 1347, 1349, 1351, 1353, 1355, 1357, 1359,
1359, 1359, 1359, 1359, 1358, 1356, 1354, 1352, 1350, 1347,
1345, 1343, 1341, 1339, 1336, 1334, 1332, 1329, 1327, 1324,
1322, 1320, 1317, 1315, 1312, 1307, 1301, 1294, 1288, 1281,
1275, 1270, 1265, 1260, 1256, 1251, 1246, 1240, 1233, 1227,
1221, 1214, 1208, 1201, 1194, 1186, 1178, 1170, 1162, 1154,
1148, 1144, 1140, 1136, 1131, 1127, 1123, 1118, 1114, 1107,
1099, 1090, 1082, 1074, 1069, 1064, 1058, 1053, 1048, 1043,
1038, 1034, 1029, 1025, 1021, 1017, 1013, 1009, 1005, 1001,
997, 994, 990, 991, 992, 994, 996, 997, 999, 998,
997, 996, 995, 994, 993, 991, 990, 989, 989, 989,
989, 989, 989, 989, 988, 986, 984, 983, 981, 980,
982, 984, 986, 988, 990, 993, 995, 997, 999, 1002,
1005, 1008, 1012};
//Global variebles used by the program
unsigned int NumSamples = sizeof(y_data) /2 ; //number of elements in y_data[] above
unsigned int QRSCount = 0; //running QRS periodic msec count
unsigned int IdleCount = 0; //running Idle perioic misc count
unsigned long IdlePeriod = 0; //idle period is adjusted by pot to set heart rate
unsigned int State = INIT; //states are INIT, QRS and IDLE
unsigned int DisplayCount = 0; //counts 50 msec to updates update the 7-segment display
unsigned int tcnt2; //Timer 2 reload value, globally available
float BeatsPerMinute; //floating point representation of the heart rate
unsigned int Bpm; //integer version of heart rate (times 10)
unsigned int BpmLow; //Lowest heart rate allowed (x10)
unsigned int BpmHigh; //Highest heart rate allowed(x10)
int Value; //place holder for analog input
unsigned int BpmValues[32] = {0, 0, 0, 0, 0, 0, 0, 0, //holds 32 last analog pot readings
0, 0, 0, 0, 0, 0, 0, 0, //for use in filtering out display jitter
0, 0, 0, 0, 0, 0, 0, 0}; //for use in filtering out display jitter
unsigned long BpmAverage = 0; //used in a simple averaging filter
unsigned char Index = 0; //used in a simple averaging filter
unsigned int DisplayValue = 0; //filtered Beats Per Minute sent to display
int loop_number = 0;
//LiquidCrystal_I2C lcd(0x27, 16, 2);
void setup(){
// Configure the output ports
pinMode(1, OUTPUT);
pinMode(4, OUTPUT); // SDA data
pinMode(5, OUTPUT); // SCL clock
// Establish the heart rate range allowed
// BpmLow = 300*(30 bpm * 10)
// BpmHigh = (60.0 / (NumSamples * 0.001)) * 10 = (60.0 / 0.543) * 10 = 1104 (110.49 * 10)
BpmLow = 300;
BpmHigh = (60.0 / ((float)NumSamples * 0.001)) * 10;
// First disable the timer overflow interrupt while we're configuring
TIMSK2 &= ~(1<<TOIE2);
// Configure timer2 in normal mode (pure counting, no PWM etc.)
TCCR2A &= ~((1<<WGM21) | (1<<WGM20));
TCCR2B &= ~(1<<WGM22);
// Select clock source: internal I/O clock
ASSR &= ~(1<<AS2);
// Disable Compare Match A interrupt enable (only want overflow)
TIMSK2 &= ~(1<<OCIE2A);
// Now configure the prescaler to CPU clock divided by 128
TCCR2B |= (1<<CS22) | (1<<CS20); //SET BITS
TCCR2B &= ~(1<<CS21); //clear bit
// We need to calculate a proper value to load the timer counter.
// The following loads the value 131 into the Timer 2 counter register
// The math behind this is:
// (CPU frequency) / (prescaler value) = 125000 Hz = 8us.
// (desired period) / 8us = 125.
// MAX(uint8) + 1 - 125 = 131;
// Save value globally for later reload in ISR
tcnt2 = 131;
// Finally load end enable the timer
TCNT2 = tcnt2;
TIMSK2 |= (1<<TOIE2);
// Read from the Heart Rate pot (Analog Input 0)
Value = analogRead(0);
// Map the Analog Input 0 range( 0 ... 1023) to the Bpm range (300 ... 1104)
Bpm = map(Value, 0, 1023, BpmLow, BpmHigh);
// To lessen the jitter or bounce in the display's least significant digit
// a movie average filter (32 value) will smooth it out.
BpmValues[Index++] = Bpm; //add latest sample to eight element array
if (Index == 32) { //handle wrap-around
Index = 0;
BpmAverage = 0;
for(int i = 0; i < 32; i++) { //summation of all values in the array
BpmAverage += BpmValues[i];
BpmAverage >>= 5; // Divide by 32 to get average
// Now update the 4-digit display format: XXX.X
// Since update is a multi-byte transfer, disable interrupts until it'sdone
noInterrupts();
DisplayValue = BpmAverage;
interrupts();
// Given the pot value (beats per minute) read in, calculate the IdlePeriod (msec)
// this value is used by the Timer2 1.0 msec interrupt service routine
BeatsPerMinute = (float)Bpm / 10.0;
noInterrupts();
IdlePeriod = (unsigned int)((float)60000.0 / BeatsPerMinute) - (float)NumSamples;
interrupts();
delay(20);
// Citire semnal ECG
int y1 = analogRead(A2);
int y2 = analogRead(A3);
int y3 = analogRead(A6);
Serial.println(y1);
Serial.println(y2);
Serial.println(y3);
// Timer2 Interrupt Service Routine
// Interrupt Service Routine (ISR) for Timer2 overflow at 1.000 msec.
// The Timer2 interrupt function is used to send the 16-bit waveform point
// to the Microchip MCP4921 D/A converter using the SPI interface.
// The Timer2 interrupt function is also used to send the current heart rate
// as read from the potentiometer every 50 Timer2 interrupts to the 7-segment display.
// The pot is read and the heart rate is calculated in the background loop.
// By running both SPI peripherals at interrupt level, we "serialize" them and avoid
// corruption by one SPI transmission being interrupted by the other.
// A state machime is implemented to accomplish this. It's states are:
// INIT - basically clears the counters and sets the state to QRS.
// QRS - outputs the next ECG waveform data point every 1.0 msec
// there are 543 of these QRS complex data points.
// IDLE - variable period after the QRS part.
// D/A holds first ECG value (936) for all of the IDLE period.
// Idle period varies to allow adjustment of the basic heart rate;
// a value of zero msec for the idle period gives 110.4 beats per min
// while the maximum idle period of 457 msec gives 30.0 bpm.
// Note that the IDLE period is calculated in the main background
// loop by reading a pot and converting its range to one suitable
// for the background period. The interrupt routine reads this
// value to determine when to stop the IDLE period.
// The transmission of the next data point to the D/A converter via SPI takes
// about 63 microseconds (that includes two SPI byte transmissions).
// The transmission of the heart rate digits to the Sparkfun 7-segment display
// takes about 350 usec (it is only transmitted every 50 Timer2 interrupts)
ISR(TIMER2_OVF_vect) {
// Reload the timer
TCNT2 = tcnt2;
// state machine
switch (State) {
case INIT:
// zero the QRS and IDLE counters
QRSCount = 0;
IdleCount = 0;
DisplayCount = 0;
// set next state to QRS
State = QRS;
case IDLE:
// since D/A converter will hold the previous value written, all we have
// to do is determine how long the IDLE period should be.
// advance idle counter and check for end
IdleCount++;
// the IdlePeriod is calculated in the main loop (from a pot)
if (IdleCount >= IdlePeriod) {
IdleCount = 0;
State = QRS;
default:
// output to the 7-segment display every 50 msec
DisplayCount++;
if (DisplayCount >= 50) {
DisplayCount = 0;
Display7Seg_Send(DisplayValue);
// void Display7Seg_Send(char *)
// Purpose: send 4 digits to SparkFun Serial 7-Segment Display (requires 4 SPI writes)
// Input: value - unsigned int version of BeatsPerMinute
// Returns: nothing
// I/O Resources: Digital Pin 10 = chip select (low to select chip)
// Digital Pin 13 = SPI Clock
// Digital Pin 11 = SPI Data
// Note: this routine takes 350 usec using an Adafruit Menta
void Display7Seg_Send(unsigned int HeartRate) {
uint8_t digit1, digit2, digit3, digit4;
unsigned int value;
// convert to four digits (set leading zeros to blanks; 0x78 is the blank character)
value = HeartRate;
digit1 = value / 1000;
value -= digit1 * 1000;
if (digit1 == 0) digit1 = 0x78;
digit2 = value / 100;
value -= digit2 * 100;
if ((digit1 == 0x78) && (digit2 == 0)) digit2 = 0x78;
digit3 = value / 10;
value -= digit3 * 10;
if ((digit1 == 0x78) && (digit2 == 0x78) && (digit3 == 0)) digit3 = 0x78;
digit4 = value;
analogWrite(4, LOW); // select the Sparkfun 7-seg display
Wire.write(digit1); // Thousands Digit
Wire.write(digit2); // Hundreds Digit
Wire.write(digit3); // Tens Digit
Wire.write(digit4); // Ones Digit
Wire.write(0x77); // set decimal points command
analogWrite(4, HIGH); // release Sparkfun 7-seg display
Here is the link to the video: Imgur: The magic of the Internet
Thank you now for your help!
