Eclipse
I’ve recently set up eclipse with support for C++ and embedded C. Is there any way I can write code for the arduino in C and get it on the board?
These articles discusses how to set up the eclipse environment to use the gcc-avr tools. http://www.cs.hut.fi/Studies/T-106.530/2006/eclipse-avr.pdf http://tinkerlog.com/2007/06/03/programming-avr-with-eclipse-and-winavr/
It may not be a big step from there to use avrdude to get the output to the board. I have no direct experience with this tho as I use the arduino IDE to write my C and C++ code ;)
I don’t know eclipse but if you can use a Makefile to build a C/C++ project then you can just use the command line instructions to set up your environment and you should be golden: http://www.arduino.cc/en/Hacking/CommandLine
I do this with emacs and when I start a new project I just copy the Makefile from another project and off I go.
You have to change some paths in the Makefile before it will work but it really is as simple as that.
Enjoy!
Charlieb
http://www.ladyada.net/library/arduino/bootloader.html
If you scroll down to "Upload sketches with AVRDUDE" you see that ladyada shows that you can upload a .hex file to the arduino using these settings.My question is more centered upon - what do I have to do to make a C file in Eclipse and get it to save a .hex file that I can then use AVR DUDE to upload.
Did you have a look at the article "Programming AVR with Eclipse and WinAVR" linked in reply#1 above?
