écrire sur une sortie numérique digitalWrite on pinout
Bonjour,
En testant un programme du site
inductancemètre
Extrait :
 * Inductance meter on favorite ATmega328P-PU running 16 MHz
 * https://www.hackster.io/sfrwmaker/inductance-meter-on-arduino-fe69b9
 * https://www.hackster.io/sfrwmaker/inductance-meter-on-tiny-stm32-29ba49 explications fonctionnement
 * https://github.com/sfrwmaker/Inductance_meter/blob/master/Arduino/l_meter.ino
 * maths: https://sites.google.com/site/vk3bhr/home/lcm1
 * Le tout issu de :  http://electronics-diy.com/lc_meter.php  +++++++++++++  relais
 * Historique:
 * https://sites.google.com/site/vk3bhr/home/index2-html
 *    https://sites.google.com/site/vk3bhr/home/index2-html/faq2  FAQ
 *        multivibrateur : https://electronics.stackexchange.com/questions/138504/square-wave-generator
#include "Arduino.h"
#include <avr/interrupt.h>
#include <LiquidCrystal.h>
 * Capture PWM signal generated on d6 pin by timer1 through d8 pin.
 * Put 100n capacitor between d6 and d8 pins.
 * The AVR cannot reset the timer on capture event, so we let the timer continue count after capture interrunt
 * we handle timer overflow event and setup 17th bit in current_capture variable
 * When the capture interrupt fires again, we save ISR1 valut into curr_capture variable preserving 17th bit.
 * Then to get the pulse width we substract previous capture value
const uint8_t CALIB_PIN     = 6;                // The reed switch that connect calibration capacitor
const uint8_t SHORT_PIN     = 7;                // The reed switch that shorts-up the internal LC cirquit
const uint8_t CAPTURE_PIN   = 8;                // Do not change, this is timer 1 capture pin
const uint8_t MODE_PIN      = 9;                // HIGH - Capacitance, LOW - inductance
// The LCD 0802 parallel interface
const uint8_t LCD_RS_PIN    = 4;
const uint8_t LCD_E_PIN     = 5;
const uint8_t LCD_DB4_PIN   = A0;
const uint8_t LCD_DB5_PIN   = A1;
const uint8_t LCD_DB6_PIN   = A2;
const uint8_t LCD_DB7_PIN   = A3;
// The buffer for pulse data
#define         BUFF_SZ     8
volatile static uint16_t    pulse[BUFF_SZ];
volatile static uint8_t     pulse_index = 0;    // Index of the pulse array
volatile static bool        pulse_ready = false;// The whole buffer has been filled
volatile static uint32_t    curr_capture  = 0;  // The current timer capture. 17-th bit can be setup by the overflow interrupt
volatile static uint16_t    prev_capture  = 0;  // Previuos value of timer captured value
// Oscillation periods for LC circuit and LC+Ccal. (with calibration capacitor) circuit, ticks
static double   ticks_LC    = 0.0;
static double   ticks_LCC   = 0.0;
const double    cal_cap_uF  = 0.001;                                    // The calibration capacitance (micro farads)
const double    four_pi_sq  = 39.4784176043574344753379639995;          // 4 * PI^2
const uint32_t  OPEN_TICKS  = 330000;                                   // The sum of ticks in the pulse[] when the circuit is open
LiquidCrystal lcd(LCD_RS_PIN, LCD_E_PIN, LCD_DB4_PIN, LCD_DB5_PIN, LCD_DB6_PIN, LCD_DB7_PIN);
void initCapture(void) {
    // Input Capture setup
    // ICNC1: Enable Input Capture Noise Canceler
    // ICES1: = 0 for trigger on falling edge
    // CS10:  = 1 set prescaler to 1x system clock (F_CPU)
    TCCR1A = 0;
    TCCR1B = (0<<ICNC1) | (0<<ICES1) | (1<<CS10);
    TCCR1C = 0;
    // Interrupt setup
    // ICIE1: Input capture
    // TOIE1: Timer1 overflow
    TIFR1 = (1<<ICF1) | (1<<TOV1);              // clear pending interrupts
    TIMSK1 = (1<<ICIE1) | (1<<TOIE1);           // enable interupts
    // Set up the Input Capture pin, ICP1, Arduino Uno pin 8
    pinMode(CAPTURE_PIN, INPUT);
    digitalWrite(CAPTURE_PIN, 0);               // floating may have 60 Hz noise on it.
// Timer1 overflow interrupt handler
ISR(TIMER1_OVF_vect) {
    curr_capture = 0x10000;                     // setup 17-th bit
// Capture interrupt handler
ISR(TIMER1_CAPT_vect) {
    TIMSK1 &= ~(1<<ICIE1);                      // Disable this interrupt handler
    curr_capture &= 0x10000;                    // Only 17th bit is matters, clear other bits
    curr_capture |= ICR1;                       // Load timer1 capture value
    pulse[pulse_index] = curr_capture - prev_capture;
    if (++pulse_index >= 8) {
        pulse_index = 0;
        pulse_ready = true;
    prev_capture = curr_capture & 0xFFFF;
    TIMSK1 |= (1<<ICIE1);                       // Enable this interrupt handler
// Absolute difference of two positive values
uint16_t abs_diff(uint16_t a, uint16_t b) {
    if (a >= b) {
        return a - b;
        return b - a;
// Oscillation period, ticks
uint32_t oscTicksSumm(bool reset) {
    if (reset) {
        pulse_ready = 0;          //bpj Clear up the buffer
        pulse_index = 0;          //bpj
        while (!pulse_ready) ;                  // Wait till the whole buffer has been filled up
    uint32_t summ = 0;
    for (uint8_t i = 0; i < 10; ++i) {
        summ    = 0;
        uint16_t min_v  = 65535;
        uint16_t max_v  = 0;
        for (uint8_t i = 0; i < BUFF_SZ; ++i) {
            uint16_t p = pulse[i];
            if (p > max_v) max_v = p;
            if (p < min_v) min_v = p;
            summ += p;
        if (abs_diff(min_v, max_v) < 100) break;
        lcd.clear();
        delay(1000);                            // Wait till the whole buffer has been filled up
    return summ;
// The square of the period, microseconds^2. Argument - period in ticks
double periodSquare(double P) {
    P /= 16.0;                                  // Convert ticks to micro seconds
    P *= P;
    return P;
// Frequently used coefficient:  (P2^2 - P1^2) / P1^2
double pCoeff(double P1, double P2) {
    P1 *= P1;
    P2 *= P2;
    double r  = (P2 - P1) / P1;
    if (r < 0) r = 0;
    return r;
void calibrate(void) {
    while (true) {
        digitalWrite(SHORT_PIN, HIGH);              // Short the external socket
        delay(100);
        // Period of the internal oscillation circuit, ticks
        ticks_LC = (double)oscTicksSumm(true) / (double)BUFF_SZ;
        digitalWrite(CALIB_PIN, HIGH);              // Connect the calibration capacitor
        delay(100);
        // Period of the internal oscillation circuit plus calibration capacitor, ticks
        ticks_LCC = (double)oscTicksSumm(true) / (double)BUFF_SZ;
        digitalWrite(CALIB_PIN, LOW);               // Disconnect the calibration capacitor
        digitalWrite(SHORT_PIN, LOW);               // Open the external socket
        delay(100);
        if (ticks_LCC > ticks_LC) break;
    //bpj !!!!!! int_cap JAMAIS utilisé  !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    double int_cap   = cal_cap_uF / pCoeff(ticks_LC, ticks_LCC);
    lcd.begin(8, 2);
    lcd.clear();
    pinMode(SHORT_PIN, OUTPUT);
    pinMode(CALIB_PIN, OUTPUT);
    pinMode(MODE_PIN, INPUT);
    initCapture();
    calibrate();
    lcd.clear();
je tombe sur (ligne 74 et 75):
Quel est l'effet (l'utilité) d'une écriture sur une pin déclarée en sortie?
Merci
Cordialement,
bidouilleelec
Écrire ZERO sur une entrée désactive les pullups.
digitalwrite
Merci hbachetti.
Il me semblait bien avoir lu quelque chose sur ce sujet.
Aaaah! la mémoire.....
Cordialement,
bidouilleelec
