Does anyone know where you can buy the EDE1144 keypad encoder ic from in UK - searched all my normal sources & don't seem to be able to locate. Is there a newer/ preferred method for connecting a 4X4 keypad to Arduino (reducing number of I/O ports from 8 to 4).
ahhh. that probably explains it then... Thanks for that Mark - It looked like a neat solution for reducing I/O required from 8 to 4 - I'll have a look for other solutions.
I bought few of those and I must say that the keypad layout for which they have been designed is laughable and NOT configurable; you have to pull the keys mechanically and re-arrange them if you can; if not then implement translation downstream.
Also the PIC needs external crystal to run and its software based debouncing algorithm some times misses a key press if the keypad happens to produce a bounce which the software ignores as a debounce.
