C:\Users\kym>npm install -g edge-impulse-cli
npm WARN deprecated request@2.88.2: request has been deprecated, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated request-promise@4.2.6: request-promise has been deprecated because it extends the now deprecated request package, see Request’s Past, Present and Future · Issue #3142 · request/request · GitHub
npm WARN deprecated @zeit/dockerignore@0.0.5: "@zeit/dockerignore" is no longer maintained
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN rollback Rolling back rxjs@6.6.7 failed (this is probably harmless): EPERM: operation not permitted, rmdir 'C:\Users\kym\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules'
npm WARN rollback Rolling back wavefile@11.0.0 failed (this is probably harmless): EPERM: operation not permitted, rmdir 'C:\Users\kym\AppData\Roaming\npm\node_modules\edge-impulse-cli\node_modules'
npm ERR! code EEXIST
npm ERR! path C:\Users\kym\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js
npm ERR! dest C:\Users\kym\AppData\Roaming\npm\edge-impulse-blocks
npm ERR! EEXIST: file already exists, cmd shim 'C:\Users\kym\AppData\Roaming\npm\node_modules\edge-impulse-cli\build\cli\blocks.js' -> 'C:\Users\kym\AppData\Roaming\npm\edge-impulse-blocks'
npm ERR! File exists: C:\Users\kym\AppData\Roaming\npm\edge-impulse-blocks
npm ERR! Remove the existing file and try again, or run npm
npm ERR! with --force to overwrite files recklessly.
npm ERR! A complete log of this run can be found in:
npm ERR! C:\Users\kym\AppData\Roaming\npm-cache_logs\2021-04-26T15_54_57_409Z-debug.log
There was a problem installing the CLI to use edgeimpulse with Arduino 33 BLE senes.
I finished installing Python and installed Node.js, but there was a problem.
I share the installation link below.
