Edit digitalWrite()
good day everyone,
I'm using minicore to program ATmega8a, and I want to edit digitalWrite() source code,
which file should I edit ?
The obvious question is why do you want to edit it ?
I want to remove some checking codes for PWM and if pin is really existed, and remove the cli(); command which disable interrupts
you would be better off writing your own function than messing around with the library...
it's here I think
void digitalWrite(uint8_t pin, uint8_t val)
  uint8_t timer = digitalPinToTimer(pin);
  uint8_t bit = digitalPinToBitMask(pin);
  uint8_t port = digitalPinToPort(pin);
  volatile uint8_t *out;
  if (port == NOT_A_PIN) return;
  // If the pin that support PWM output, we need to turn it off
  // before doing a digital write.
  if (timer != NOT_ON_TIMER) turnOffPWM(timer);
  out = portOutputRegister(port);
  uint8_t oldSREG = SREG;
  cli();
  if (val == LOW) {
    *out &= ~bit;
    *out |= bit;
  SREG = oldSREG;
As @J-M-L says, just do not use digitalWrite(), do a direct port address.
