Edit Function doesn't pick the respective values
i’m creating a ticketing system and i need some assistance. The code directly below displays the database records and the delete works fine. The edit however isn’t picking the values in the various fields.
<?Php
        require "config.php";
        $page_name="currentout.php";
        $start=$_GET['start'];
        if(strlen($start) > 0 and !is_numeric($start)){
        echo "Data Error";
        exit;
        $eu = ($start - 0);
        $limit = 10;
        $this1 = $eu + $limit;
        $back = $eu - $limit;
        $next = $eu + $limit;
        $nume = $dbo->query("select count(id) from receipt")->fetchColumn();
        echo "<TABLE class='t1'>";
        echo  "<tr><th>ID</th><th>Name</th><th>Pass</th><th>Amount</th><th>Action</th></tr>";
        $query=" SELECT * FROM receipt  limit $eu, $limit ";
        foreach ($dbo->query($query) as $row) {
        @$m=$i%2;
        @$i=$i+1;
        echo "<tr class='r$m'><td>$row[id]</td><td>$row[name]</td><td>$row[phone_num]</td><td>$row[Amount]</td><td><a href='delete.php?id=$row[id]'>delete</a></td><td><a href='edit.php?id=$row[id]'>Edit</a></td></tr>";
        echo "</table>";
        if($nume > $limit ){
        echo "<table align = 'center' width='50%'><tr><td  align='left' width='30%'>";
        if($back >=0) {
        print "<a href='$page_name?start=$back'><font face='Verdana' size='2'>PREV</font></a>";
        echo "</td><td align=center width='30%'>";
        $i=0;
        $l=1;
        for($i=0;$i < $nume;$i=$i+$limit){
        if($i <> $eu){
        echo " <a href='$page_name?start=$i'><font face='Verdana' size='2'>$l</font></a> ";
        else { echo "<font face='Verdana' size='4' color=red>$l</font>";}
        $l=$l+1;
        echo "</td><td  align='right' width='30%'>";
        if($this1 < $nume) {
        print "<a href='$page_name?start=$next'><font face='Verdana' size='2'>NEXT</font></a>";}
        echo "</td></tr></table>";
The code below is edit.php. It’s supposed to display the various fields when clicked to allow for editing but it isn’t picking any field, PLEASE assist.
<?Php
$sql = "SELECT FROM receipt  WHERE ID=  :ID";
$stmt = $dbo->prepare($sql);
$stmt->bindParam(':ID', $_GET['id'], PDO::PARAM_INT);
$stmt->execute();
    <form action="update.php" method="post" enctype="multipart/form-data">
    <table align="center">
   <tr>
   <td> <label><strong>Full Names</strong></label></td>
     <td> <input type='text' name='name' value=" <?php echo $row['name']; ?>"  />
      <input type="hidden" name="id" value="<?php echo $id; ?> " />
</td>
    </tr>
    <tr>
     <td><label><strong>ID/Passport No. </strong></label></td>
  <td> <input type="text" name="pass" value="<?php echo $row['id_passno']; ?> " />
</td>
  </tr>
   <tr>
    <td> <label><strong>Phone No. </strong></label></td>
    <td><input type="text" name="phone" value="<?php echo $row['phone_num']; ?>" />
</td>
    </tr>
    <tr>
    <td> <label><strong>Amount (KShs.) </strong></label></td>
    <td><input type="text" name="amount" value="<?php echo $row['Amount']; ?> "/>
</td>
   </tr>
    <tr>
  <td>
          <input type="reset" name="Reset" value="CANCEL" onClick="return confirm('Discard changes?');" />
</td>
     <td>
          <input type="submit" name="Submit2" value="SUBMIT" />
      </td>
   </tr>
</table>
</form>
To paraphrase Moe Sizlack... You're a long way from home, PHP-boy.
While you may get help here (it is a friendly place) you are much more likely to get help on a PHP forum.
On a side note: does your question have anything to do with Arduino?
Shouldn't you include some fields in that? Or maybe just an asterisk (for all fields)
ie
$sql = "SELECT * FROM receipt  WHERE ID=  :ID";
