hi everyone
i use node mcu esp8266 and RemoteXY app to control a led.
I've got a class can set time-off and time-on for led without delay function, but when i add it to my sketch and upload it to nodemcu
my phone can't see it's wifi network .
the class is working very well with UNO,
can i add the class to remotexy library and make it work with the app.
or any way to make it work please .
the class and void setup and loop is
class Flasher
// Class Member Variables
// These are initialized at startup
int ledPin; // the number of the LED pin
long OnTime; // milliseconds of on-time
long OffTime; // milliseconds of off-time
// These maintain the current state
int ledState; // ledState used to set the LED
unsigned long previousMillis; // will store last time LED was updated
// Constructor - creates a Flasher
// and initializes the member variables and state
public:
Flasher(int pin, long on, long off)
ledPin = pin;
pinMode(ledPin, OUTPUT);
OnTime = on;
OffTime = off;
ledState = LOW;
previousMillis = 0;
void Update()
// check to see if it's time to change the state of the LED
if((ledState == HIGH) && (currentMillis - previousMillis >= OnTime))
ledState = LOW; // Turn it off
previousMillis = currentMillis; // Remember the time
digitalWrite(ledPin, ledState); // Update the actual LED
else if ((ledState == LOW) && (currentMillis - previousMillis >= OffTime))
ledState = HIGH; // turn it on
Flasher led1(12, 100, 400);
Flasher led2(13, 350, 350);
led1.Update();
led2.Update();
