Edit PID code to receive data from TC Breakoutboard MAX31855
Hi all
I have a code for a PID Temperature controller that I made a while back.
It was basically an arduino reading an analog voltage signal from a TC amplifier, a 2x16LCD (without serial backpack), a few buttons for some control, and the digital PID output went to a MOSFET to control a heater.
Now I have a new kit I am messing with. What is different now is I have my temperature being supplied via one wire (SPI) from a Thermocouple Amplifier MAX31855 breakout board, I also have a 2x16 LCD from sparkfun that’s got the serial backpack for one wire control, lastly I have added a analog (0-5v) LED bar graph so I can monitor the output. This new version will also have the 3 buttons (on/off, temp up, temp down)
Now I want to basically migrate all I had (funtion-wise) from the old code into a simpler code for the new hardware since the hardware has been simplified to digital communication.
Here’s the original code. .
#include <EEPROM.h>
#include <LiquidCrystal.h>
#include <PID_v1.h>
#include <SPI.h>
double Setpoint, Input, Output;
double Kp=4, Ki=1, Kd=2, LoLIM=10, HiLIM=255;
double SampleTime=250;
LiquidCrystal lcd(12, 11, 8, 4, 3, 2);
const int onPin = 5;     //pin to trigger heater
const int upPin = 6;     //  pin to increase temp
const int downPin = 7;   //pin to decrease temp
int buttonState = 0;     // variable for reading the pin status
int DownPushed = 0;
int UpPushed = 0;
int OnPushed = 0;
int PID_ON = 0;
int UpdScr = 0;
int inpt;
int gap;
int S_gap;
int count;
int EEPROM_ADDR;
void UpdateEEPROM() {
  int val, wr;
  val = (int) Setpoint;
  wr = val>>8;
  EEPROM.write(EEPROM_ADDR, wr);
  wr = val & 0XFF;
  EEPROM.write(EEPROM_ADDR+1, wr);
void LoadEEPROM() {
  int val;
  val = EEPROM.read(EEPROM_ADDR);
  val = val <<8;
  val +=EEPROM.read(EEPROM_ADDR+1);
  Setpoint = val;
unsigned long lastTime, lShowTime;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, Kp, Ki, Kd, DIRECT);
  Serial.begin( 19200 );
  //initialize the variables we're linked to
  Input = analogRead(0);
  LoadEEPROM();
  if( (Setpoint +1.) < 0.001)
    Setpoint = 575;    //    Setpoint = xxx;
  // Declare inputs
  pinMode(onPin, INPUT);    // declare pushbutton as input, turn PID ON
  pinMode(upPin, INPUT);    // declare pushbutton as input, increase Setpoint
  pinMode(downPin, INPUT);  // declare pushbutton as input, decrease Setpoint
  //turn the PID on STANDBY
  myPID.SetOutputLimits(LoLIM, HiLIM);
  myPID.SetMode(AUTOMATIC);
  myPID.SetSampleTime(SampleTime);
  myPID.SetTunings(Kp, Ki, Kd);
  lShowTime = lastTime = millis();
  // set up the LCD's number of columns and rows:
  lcd.begin(16,2);
  count = 0;
  EEPROM_ADDR = 30;
  buttonState = digitalRead(onPin);
  if (buttonState == HIGH) {
    // turn HEATER on, but prime first:
    PID_ON =1;
  else {
    myPID.SetMode(MANUAL);
    Output = 0;
    PID_ON =0;
  myPID.Compute();
  analogWrite(9,Output);
  // I would not change these lines, because you are expecting 250 ms for a "push"
  // that is if you hold button for more then 1/4 second,
  if(digitalRead(upPin)==HIGH) {
    if (millis()-lastTime >= 250) {
      Setpoint+=5;
      UpdateEEPROM();
      lastTime=millis();
      UpdScr = 1;
  if(digitalRead(downPin)==HIGH) {
      Setpoint-=5;
      UpdateEEPROM();
      lastTime=millis();
      UpdScr = 1;
  //and output to LCD
  if( (millis() - lShowTime > 100 ) || UpdScr ) {
    UpdScr = 0;
    lcd.setCursor(0,0);
    //if heater is on - show *
    //if not - empty
    if( PID_ON ==1 ) {
      lcd.print("*");
    else {
      lcd.print(" ");
    lcd.print("SET.TEMP-> ");
    lcd.print((int)(Setpoint) );
    lcd.setCursor( 0,1);
    lcd.print("AIR.TEMP-> ");
    inpt = (inpt *5 + Input)/6;
    count = (count +1)%6;
    if(count == 0) {
      if( inpt < 100) lcd.print( " ");
      lcd.print( inpt );
    lShowTime = millis();
I guess I just would like to know the best way to send the serial data from the MAX31855 board to the “Input” of the PID, achieve a similar readout on the new LCD as I had on my older LCD, and eventually be able to send the output level of the PID to the analog LED bar graph(there must be a trick to convert the digital PID output to analog).
Any help is greatly appreciated!! Tips, code, or reference material!!
Serial LCD Kit Quickstart Guide - SparkFun Electronics <–LCD
http://forum.arduino.cc/index.php?topic=208061.0 ← MAX31855 Thermocouple Amp Board
GitHub - thisdroneeatspeople/SparkSoftLCD: Single-pin Arduino Serial Interface Library for SparkFun Serial LCDs <— Something I should probably use?
Here’s a sample of code to read the MAX31855 TC Board
//    FILE: max31855_demo1.ino
//  AUTHOR: Rob Tillaart
// VERSION: 0.1.01
// PURPOSE: thermocouple lib demo application
//    DATE: 2014-01-02
//     URL:
// Released to the public domain
#include "MAX31855.h"
const int doPin = 7;
const int csPin = 6;
const int clPin = 5;
MAX31855 tc(clPin, csPin, doPin);
  Serial.print("Start max31855_demo: ");
  Serial.println(MAX31855_VERSION);
  tc.begin();
  int status = tc.read();
  if (status != 0)
    Serial.print("stat:\t\t");
    Serial.println(status);
  float temp = tc.getTemperature();
  int m = temp*10 - 200;
  Serial.print(temp);
  Serial.print('\t');
  for (int i=0; i< m; i++) Serial.write(']');
Well I now realize the entries for the EEPROM are so hold the Setpoint value so when I adjust it through my pushbuttons it retains whatever its set at while the loop runs.
I got the LCD to work and display the temperature from the serial breakout board… Its a butchered modification but its working so far.
The weird thing is at the end when I try and send the “Setpoint” to the LCD its a number like 27,135 instead of the default 575.
I put
LCD.print((int)Setpoint);
Something makes me think that:
UpdateEEPROM()
LoadEEPROM()
have something to do with that.
How can I plug the thermocouple.readFarenheit() into the PID input instead of how it previously was done by Input = analogRead(0)
Here’s what i’ve done.
#include <EEPROM.h>
#include <PID_v1.h>
#include <SPI.h>
#include "Adafruit_MAX31855.h"
#include <SoftwareSerial.h>
const int onPin = 8;     //pin to trigger heater
const int upPin = 9;     //  pin to increase temp
const int downPin = 11;   //pin to decrease temp
int DownPushed = 0;
int UpPushed = 0;
int OnPushed = 0;
int PID_ON = 0;
int UpdScr = 0;
int inpt;
int gap;
int S_gap;
int count;
int EEPROM_ADDR;
int thermoCLK = 5;
int thermoCS = 4;
int thermoDO = 3;
// Initialize the Thermocouple
Adafruit_MAX31855 thermocouple(thermoCLK, thermoCS, thermoDO);
float degF = 0.00;
// variable to store the value
double c = thermocouple.readCelsius();
  int val, wr;
  wr = val>>8;
  wr = val & 0XFF;
void LoadEEPROM() {
  int val;
  val = val <<8;
  Setpoint = val;
#define txPin 2
SoftwareSerial LCD = SoftwareSerial(0, txPin);
// since the LCD does not send data back to the Arduino, we should only define the txPin
const int LCDdelay=10;  // conservative, 2 actually works
  pinMode(txPin, OUTPUT);
  LCD.begin(9600);
  clearLCD();
  lcdPosition(0,0);
  LCD.print("TEST");
  clearLCD();
  LoadEEPROM();
  // Declare inputs
  count = 0;
  EEPROM_ADDR = 30;
  degF = (thermocouple.readFarenheit());
  if (buttonState == LOW) {
    PID_ON =1;
  else {
    Output = 0;
    PID_ON =0;
  myPID.Compute();
      Setpoint+=5;
      UpdateEEPROM();
      lastTime=millis();
      UpdScr = 1;
      Setpoint-=5;
      UpdateEEPROM();
      lastTime=millis();
      UpdScr = 1;
  //and output to LCD status and readings
  if( PID_ON ==1 ) {
      lcdPosition(0,0);
      LCD.print("*");
    else {
      lcdPosition(0,0);
      LCD.print(" ");
  lcdPosition(0,1);
    LCD.print("SetPoint= ");
    lcdPosition(0,10);
    lcdPosition(1,1);
    LCD.print("AirTemp=");
    lcdPosition(1,9);
    LCD.print((int)degF);
I admit that I have not read your post thoroughly, but the simple answer would seem to be.
  Input = thermocouple.readFarenheit();
There may be issues with data types though because Input is a double and it looks like thermocouple.readFarenheit() returns a float in you program.
