Hello, I'm new and starting my adventure with Arduino. Can anyone help me edit the sketch I found here on the forum? it has 6 PWM LEDs and I need 7 PWM LEDs. Thank you in advance.
//BLOCK COMMENT
// https://forum.arduino.cc/t/knight-rider-pwm/902477
#define ProjectName "Knight rider PWM"
// CONSTANT DEFINITION
// you may need to change these constants to your hardware and needs
constexpr byte Output_[] {3, 5, 6, 9, 10, 11};
constexpr byte ledSeq[][sizeof(Output_)] {
{255 >> 0, 255 >> 2, 255 >> 3, 255 >> 4, 255 >> 5, 255 >> 6},
{255 >> 1, 255 >> 0, 255 >> 4, 255 >> 5, 255 >> 6, 255 >> 7},
{255 >> 2, 255 >> 1, 255 >> 0, 255 >> 6, 255 >> 7, 255 >> 8},
{255 >> 3, 255 >> 2, 255 >> 1, 255 >> 0, 255 >> 8, 255 >> 8},
{255 >> 4, 255 >> 3, 255 >> 2, 255 >> 1, 255 >> 0, 255 >> 8},
{255 >> 5, 255 >> 4, 255 >> 3, 255 >> 2, 255 >> 1, 255 >> 0},
{255 >> 6, 255 >> 5, 255 >> 4, 255 >> 3, 255 >> 2, 255 >> 0},
{255 >> 7, 255 >> 6, 255 >> 5, 255 >> 4, 255 >> 0, 255 >> 1},
{255 >> 8, 255 >> 7, 255 >> 6, 255 >> 0, 255 >> 1, 255 >> 2},
{255 >> 8, 255 >> 8, 255 >> 0, 255 >> 1, 255 >> 2, 255 >> 3},
{255 >> 8, 255 >> 0, 255 >> 1, 255 >> 2, 255 >> 3, 255 >> 4},
{255 >> 0, 255 >> 1, 255 >> 2, 255 >> 3, 255 >> 4, 255 >> 5},
// VARIABLE DECLARATION AND DEFINTION
unsigned long currentTime;
unsigned int sequence;
struct TIMER {
unsigned long duration;
unsigned long stamp;
TIMER blink_{100, 0};
// FUNCTIONS
bool checkTimer(TIMER & time_) {
if (currentTime - time_.stamp >= time_.duration) {
time_.stamp = currentTime;
return true;
} else return false;
Serial.println(F("."));
Serial.print(F("File : ")), Serial.println(__FILE__);
Serial.print(F("Date : ")), Serial.println(__DATE__);
Serial.print(F("Project: ")), Serial.println(ProjectName);
for (auto Output : Output_) pinMode(Output, OUTPUT);
void loop () {
currentTime = millis();
if (checkTimer(blink_)) {
int element = 0;
for (auto led : Output_) analogWrite(led, ledSeq[sequence][element++]);
sequence++;
sequence = sequence % (sizeof(ledSeq) / sizeof(ledSeq[0]));
