Edit sketch
hello everyone, I am a neophyte I wanted to ask how to replace the two buttons of this project with two PIR sensors? thanks : Smiley-confuse:
#define led_1 8 // il pin 8 è usato per il LED
#define led_2 9 // il pin 9 è usato per il LED
#define btn_pin1 2 // il pin 2 è usato per il PULSANTE 1
#define btn_pin2 3 // il pin 3 è usato per il PULSANTE 2
// Variabili
int in1 = 0;
int in2 = 0;
pinMode(led_1, OUTPUT);
pinMode(led_2, OUTPUT);
pinMode(btn_pin1, INPUT);
pinMode(btn_pin2, INPUT);
in1 = digitalRead(btn_pin1);
in2 = digitalRead(btn_pin2);
if (in1 == HIGH){ // PULSANTE 1 premuto
digitalWrite(led_1, HIGH); // accensione LED 1
delay (2000); // ritardo di 2 sec
digitalWrite(led_1, LOW); // se il PULSANTE 1 non premuto LED 1 spento
if (in2 == HIGH){ // PULSANTE 2 premuto
digitalWrite(led_2, HIGH); // accensione LED 2
digitalWrite(led_2, LOW); // seil PULSANTE 2 non premuto LED 2 spento
What are the outputs from the PIRs when nothing is detected and when something is detected ?
images found on the internet how to replace buttons with pir sensors? thanks
UKHeliBob:
when it detects a person entering a room.tanks
vincenzo341:
That doesn't answer the question.
Please remember to use code tags when posting code
AWOL:
I'm sorry but I'm no expert I found this project, however, instead of the buttons say that you can put the detection sensors, however, I think the pir sensors does not know how to do, I would like to use it to turn on the light of a room as I passed and then it shut down to my way out of the room.
The point is a PIR sensor senses, or does not sense. motion. A switch is, or is not, pressed. One can easily be interchanged for the other.
The questions, really, are:
What have you tried?
What happened?
What did you expect to happen?
Please help us to help you.
What is the normal state of the PIR output, HIGH or LOW ?
Does it change when a person is detected ?
UKHeliBob:
this is the project. thanks again
In view of the fact that the link you provided is to a page in Italian your questions may be better answered in the Italian section of this forum.
UKHeliBob:
ok tanks
