editable pin numbers
Hi Guys, i am pretty new to arduino and am working on a project at the moment wich requires a pin code to start the process, i also have a menu function to change various settings in the process, however within this menu i want to be able to change the pin number. At the moment i set the pins at the begining with
char PinCode[] = "123456"; // main operating pin code
char AdminCode[] = "654321"; //code to access settings menu
i wonder if you could help me with the code to edit these numbers.
much appreciated.
The title of the thread is a bit misleading. If I understand correctly, the "pin" means a passcode, not arduino analog or digital I/O pins, right?
If you want to change this pin, how are you relaying the new code to arduino? Serial.read? A keypad or a few buttons? A twist knob with something to turn?
My apologies, yes i do mean passcode, i will be inputting the code via keypad, i've already created an editable clock wher i can edit hours,mins,secs in the project, but cant seem to get the idea of inputting strings of numbers like my 6 digit passcode.
I doubt it’s much different to what you are already doing for the clock.
Assuming you have a function to get a numeric value from a key press and you want to store the values as ASCII characters then
memset (PinCode, 6, 0);  // clear the array
for (int i = 0; i < 6; i++)
  PinCode[i] = getKey() + '0';
Is about what you would do. Of course you need to handle the method getting to the password entry code, exiting if someone wants to start again etc.
Rob
I suspect if you use the keypad library on arduino playground, it already translates the keys into ASCII characters from '0' to '9', and then '*' and '#'. Can you show us how you did it in your clock project?
Yes i used the keypad tutorial.
#include <Keypad.h>
#include <LiquidCrystal.h>
#include <LedControl.h>
#include <MsTimer2.h>
LedControl lc=LedControl(4,3,2,1);
const byte ROWS = 4; //four rows
const byte COLS = 4; //four columns
char keys[ROWS][COLS] = {
{'1','2','3','A'},
{'4','5','6','B'},
{'7','8','9','C'},
{'*','0','#','D'}
byte rowPins[ROWS] = {7, 8, 9, 10}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {13, 12, 11, 6}; //connect to the column pinouts of the keypad
my A,B,C,D keys are used for menu, yes, no and cancel. the clock edit is done like this:
void clockSet(){
lcd.clear();
char timeInt;
lcd.setCursor(0, 0);
lcd.print("Enter Admin Pin");
if (getAdminPin() == true){
lcd.clear();
lcd.print("Enter Hours");
do{
timeInt = keypad.getKey();
while(timeInt == '\0' || timeInt < '0' || timeInt > '6');
hour = (timeInt - '0') * 10;
do{
while(timeInt == '\0');
hour = (timeInt - '0') + hour;
lcd.clear();
timeInt = 'L';
lcd.print("Enter Minutes");
do{
while (timeInt < '0' || timeInt > '6'){
minute = (timeInt - '0') * 10;/
do{
minute = (timeInt - '0') + minute;
lcd.clear();
timeInt = 'L';
lcd.print("Enter Seconds");
do{
second = (timeInt - '0') * 10;
do{
second = (timeInt - '0') + second;
timeInt = 'L';
repeatTimerEdit = 1;
}//end of getAdminPin == true
if(getAdminPin == false){
lcd.print("Incorrect");
lcd.clear();
lcd.print("Enter Pin");
}//end of timer edit function
Please modify your post with the code button "#". See the button in red square.
Yes please modify the post and put the code inside code tags.
Meanwhile
  // a lot of stuff
should be
  // a lot of stuff
I'm not even sure the first version would have compiled.
But aren't we supposed to be looking at the PIN entry, where's the source for getAdminPin() ?
Rob
