editing ftp code to write the file and send it
hi everyone
i am trying to edit the code in Arduino Playground - FTP
because this code is sending empty files to the server
i need to write random string in it before sending it
first i tried using any line, write it in the txt file then send it to the ftp server, but looks like the file always uploaded empty
i took the SD card and out it in my laptop, and i could see the text in it, but when the arduino writes it and send it, it get sent empty
if i used the file without trying to write in it, the file is sent successfully , but when i try to write it using the code it doesnt work
the code after editing is
char fileName[13] = "create.txt";
int s=1;
  digitalWrite(4,HIGH);
  if(SD.begin(4) == 0)
    Serial.println(F("SD init fail"));
  Ethernet.begin(mac, ip);
  delay(2000);
  Serial.println(F("Ready. Press f or r"));
  byte inChar;
  inChar = Serial.read();
  if(s == 1)
    if(doFTP()) {Serial.println(F("FTP OK"));
    s++;
    else Serial.println(F("FTP FAIL"));
  if(inChar == 'r')
    readSD();
File fh;
byte doFTP()
#ifdef FTPWRITE
  fh = SD.open(fileName,FILE_WRITE);
#else
#endif
  if(!fh)
    Serial.println(F("SD open fail"));
    return 0;
#ifndef FTPWRITE
  if(!fh.seek(0))
    Serial.println(F("Rewind fail"));
    fh.close();
    return 0;
#endif
  Serial.println(F("SD opened"));
   fh.println("*****random*****");
fh.close();
  if (client.connect(server,21)) {
    Serial.println(F("Command connected"));
  else {
    fh.close();
    Serial.println(F("Command connection failed"));
    return 0;
  if(!eRcv()) return 0;
  client.println(F("USER admin"));
  client.println(F("PASS 1122"));
  client.println(F("SYST"));
  client.println(F("Type I"));
  client.println(F("PASV"));
  char *tStr = strtok(outBuf,"(,");
  int array_pasv[6];
  for ( int i = 0; i < 6; i++) {
    tStr = strtok(NULL,"(,");
    array_pasv[i] = atoi(tStr);
    if(tStr == NULL)
      Serial.println(F("Bad PASV Answer"));
  unsigned int hiPort,loPort;
  hiPort = array_pasv[4] << 8;
  loPort = array_pasv[5] & 255;
  Serial.print(F("Data port: "));
  hiPort = hiPort | loPort;
  Serial.println(hiPort);
  if (dclient.connect(server,hiPort)) {
    Serial.println(F("Data connected"));
  else {
    Serial.println(F("Data connection failed"));
    client.stop();
    fh.close();
    return 0;
#ifdef FTPWRITE
  client.print(F("STOR "));
  client.println(fileName);
#else
  client.print(F("RETR "));
#endif
  if(!eRcv())
    dclient.stop();
    return 0;
#ifdef FTPWRITE
  Serial.println(F("Writing"));
  byte clientBuf[64];
  int clientCount = 0;
  while(fh.available())
    clientBuf[clientCount] = fh.read();
    clientCount++;
    if(clientCount > 63)
      dclient.write(clientBuf,64);
      clientCount = 0;
  if(clientCount > 0) dclient.write(clientBuf,clientCount);
#else
  while(dclient.connected())
    while(dclient.available())
      char c = dclient.read();
      fh.write(c);
      Serial.write(c);
#endif
  dclient.stop();
  Serial.println(F("Data disconnected"));
  client.println(F("QUIT"));
  client.stop();
  Serial.println(F("Command disconnected"));
  fh.close();
  Serial.println(F("SD closed"));
  return 1;
byte eRcv()
  byte respCode;
  byte thisByte;
  while(!client.available()) delay(1);
  respCode = client.peek();
  outCount = 0;
  while(client.available())
    thisByte = client.read();
    Serial.write(thisByte);
    if(outCount < 127)
      outBuf[outCount] = thisByte;
      outCount++;
      outBuf[outCount] = 0;
  if(respCode >= '4')
    efail();
    return 0;
  return 1;
void efail()
  byte thisByte = 0;
  client.stop();
  fh.close();
void readSD()
  fh = SD.open(fileName,FILE_READ);
  if(!fh)
    return;
    Serial.write(fh.read());
  fh.close();
i only added the fh.println()
please help
I really don't understand what you are doing.
#ifdef FTPWRITE
#else
#endif
If the name FTPWRITE is defined, open a file for write. If it isn't defined, open the same file, the same way. What is the purpose of the conditionals?
fh.close();
Unconditionally open the file that is already open. Write the string containing random, which is anything but random, and then close the file.
The fine folks at http://snippets-r-us.com might be able to help you with your snippets.
PaulS:
#ifdef FTPWRITE
#else
#endif
  fh.println("random");
fh.close();
thank you for your reply
i found fixed the problem by retrying to edit the code
