Hi.
My arduino nano board (I'm not sure about it's authenticity) works fine with the desktop editor.
On the web editor I get "programmer is not responding". This is due to the baud rate not being set correctly "-b115200". If I run the avrdude command myself with a baud rate of 57600 it uploads fine.
Are all nanos suppose to be 115200 ? Is there some way to change the baud rate on the web editor ?
The baud rate I set the port to in device manager in windows seemingly doesn't make a difference.
When simply change the -b115200 to -b57600 and run that myself everything works fine.
I also tried changing all the 115200's in the avrdude.conf to 57600, which didn't make a difference.
