Hello Guys,
I'm using PID library by brett to regulate the EC Fan Centrifugal speed (PWM) , I want the value of Air speed to be between 0.25 m/s and 0.5 m/s , if the Sensor speed is < 0.25m/s or > 0.5m/s , I want an Alarm (buzzer + red led) to go on but after the system is stable , i mean a delay of lets say 3 minutes , I tried this code but the Alarm is always off !
#include <PID_v1.h>
#include <LiquidCrystal.h>
//------------------OUTPUT_PINs------------------------------
int ALARM = 3;
int Red_Led = A4;
int FAN_PWM = 9;
int in1_FAN_Relay = A5 ; // the Relay PIN , turned on by setting it to LOW
LiquidCrystal lcd(12, 11, 4, 5, 6, 7);
boolean SwitchFANState = false; // if it was in the main loop it would be reset every time thorough the code
//-------------------INPUT_PINs------------------------------------
const int Switch_FAN = A2; // when the switch on the relay is and the EC Fan is on
int AirFlow_Sensor = A1;
//--------------------PID_variables--------------------------
double Setpoint, Input , Output;
//Define the aggressive and conservative Tuning Parameters
double aggKp = 4, aggKi = 18, aggKd = 0;
double consKp = 2, consKi = 5, consKd = 1;
//Specify the links and initial tuning parameters
PID myPID(&Input, &Output, &Setpoint, consKp, consKi, consKd, P_ON_M, DIRECT);
//---------------------Timing----------------------------------------
unsigned long previousMillis = 0;
//-------------------Inputs------------------------
pinMode(Switch_FAN, INPUT);
lcd.begin(16, 2);
//---------------------Outputs----------------
digitalWrite(in1_FAN_Relay , HIGH);
pinMode(in1_FAN_Relay, OUTPUT);
Setpoint = 0.25; // the desired AirFlow speed in m/s
//turn the PID on
myPID.SetMode(AUTOMATIC);
//Serial.begin(9600);
Input = analogRead(AirFlow_Sensor);
Input = (Input * 5.0 * 100.0) / 256000.0; // to get AirFlow speed in m/s , the sensor have values from 0 to 2 m/s
unsigned long currentmillis = millis();
if (currentmillis - previousMillis > 250)
lcd.clear();
lcd.print("AirFlow= ");
lcd.setCursor(0, 1);
lcd.print(Input);
lcd.print(" m/s");
previousMillis = currentmillis;
double gap = abs(Setpoint - Input); //distance away from setpoint
if (gap < 0.05)
{ //we're close to setpoint, use conservative tuning parameters
myPID.SetTunings(consKp, consKi, consKd);
//we're far from setpoint, use aggressive tuning parameters
myPID.SetTunings(aggKp, aggKi, aggKd);
SwitchFANState = digitalRead(Switch_FAN);
if (SwitchFANState == HIGH)
digitalWrite(in1_FAN_Relay, LOW); // turn on Relay
myPID.Compute(); // get Output PWM value
analogWrite(FAN_PWM, Output);
//delay(1000UL * 60 * 3);
//------------------ALARM CODE----------------------------------
unsigned long now = millis();
if (now - previousMillis >= (3 * 60 * 1000UL))
previousMillis = now;
if (Input < 0.20) {
digitalWrite(Red_Led, HIGH);
tone(ALARM, 1000, 500);
digitalWrite(Red_Led, LOW);
noTone(ALARM);
if (Input > 0.55)
noTone(ALARM);
} else
analogWrite(FAN_PWM, 0);
digitalWrite(in1_FAN_Relay, HIGH);
noTone(8);
I don't want to use delay , because it's going to block the PID good work.
thank you
