Eeco binary micro switch code
Hi all, just thought I'd leave this here as i couldn't find it myself so I wrote it for anyone to use:
Using a binary rotary micro switch (eeco micro dip 3500) to control cases.
// Pins connected to the rotary dip switch using the values 1,2,4,5
#define SWITCH_PIN_1 7
#define SWITCH_PIN_2 4
#define SWITCH_PIN_4 6
#define SWITCH_PIN_8 5
const int switchPins[4] = {SWITCH_PIN_1, SWITCH_PIN_2, SWITCH_PIN_4, SWITCH_PIN_8};
int sizeofswitch = sizeof(switchPins) / sizeof(int);
  // Configure switch pins as inputs
  Serial.begin(57600);
  Serial.println("Power on ...");
  Serial.println(sizeofswitch);
    pinMode(SWITCH_PIN_1, INPUT_PULLUP);
    Serial.println("Pin");
    Serial.println(SWITCH_PIN_1);
    Serial.println("turned on");
    pinMode(SWITCH_PIN_2, INPUT_PULLUP);
    Serial.println(SWITCH_PIN_2);
    pinMode(SWITCH_PIN_4, INPUT_PULLUP);
    Serial.println(SWITCH_PIN_4);
    pinMode(SWITCH_PIN_8, INPUT_PULLUP);
    Serial.println(SWITCH_PIN_8);
  int value = readDipSwitch();
  switch (value) {
    case 0:
      // Perform action for value 0
      Serial.println("0");
    case 1:
      // Perform action for value 1
      Serial.println("1");
    case 2:
      // Perform action for value 2
      Serial.println("2");
    case 3:
      // Perform action for value 3
      Serial.println("3");
    case 4:
      // Perform action for value 4
      Serial.println("4");
    case 5:
      // Perform action for value 5
      Serial.println("5");
    case 6:
      // Perform action for value 6
    case 7:
      // Perform action for value 7
    case 8:
      // Perform action for value 8
    case 9:
      // Perform action for value 9
    // Add more cases as needed
    default:
      // Default action if the value doesn't match any case
int readDipSwitch() {
  int value = 0;
  // Read the state of each switch pin
  for (int k = 0; k < sizeofswitch; k++) {
    if (digitalRead(switchPins[k]) == HIGH) {
      value |= (1 << k);// If the pin is HIGH, set the corresponding bit in the value
  return value;
Many thanks.
