Eelegoo DC Motors Lesson 29 Problem
Hello...I have the board wired correctly with the power supply, etc. The motor follows the program but will not reverse direction as it should. Clockwise is fine..when it should be running counterclockwise it sits idle....i know the motor can reverse because I hard wired it to check....
Pins are 3,4,5 as per the program...5 enable, 3 and 4 low..high outputs for direction....any help much appreciated...bill b
You need to post your code and full details of the hardware. Most of us will have absolutely no experience of Eelegoo DC motors lessons.
Ok,,,thank you...
