Eeprom address loction
hello , i'm new in this field . i want know how to got number of address available in EEPROM 64K (8192 x 8).??? what is page write in memory?? address of page??how many line in page???
Hello, do yourself a favour and please read How to get the best out of this forum
providing the exact spec of your EERPOM would help answer... (and you could figure it out by looking at the datasheet of your EEPROM)
Presumably you are asking about an external EEPROM. If so then please provide a link to the device that you are using
as i already told i'm new so i can't under stand data sheet , data sheet tell much more but i don't understand
The 8192 is the number of address locations in your EEPROM i.e. you can save a byte from address zero to address 8191
As far as page size, there's a good chance it's 32 bytes. That's the most common page size for EEPROM
So post a link to it here
thank you sir ,
why we required page write . Please give me brief idea abut it.
is page have address and in which condition we use page write??????????
Page write is more efficient than individual byte writes. This allows your application to send 32 bytes to the EEPROM to write in a single transaction, instead of 32 individual byte writes.
read stuff about EEPROM then, don't stay in the dark - build up knowledge
here is an application note that might be informative for example
https://www.st.com/resource/en/application_note/an2014-how-a-designer-can-make-the-most-of-stmicroelectronics-serial-eeproms-stmicroelectronics.pdf
Thank a lot . i will be grateful to you :pray
