Hello!
I am currently working on a project with a barrier based on esp8266 nodemcu. The difference is that I have to do it not with a servo, but with a simple gear motor.
When the touch button (TTP223) is pressed, the motor should rotate forward for 4 seconds and open the guard. And when you touch it, it should rotate backwards for 1 second and close the fence
That's where I had a problem.
The motor is not as smart as the servo. He does not understand whether to open the fence or close it. If you turn off the device when opening the fence and then turn it on, then when touching the motor tries to open the already open fence.
I want to solve this problem using EEPROM.
That is, when touched, the motor opens the fence and remembers the position (for example, open), and if there is still a touch, the motor closes the fence and clears and adds a new value to the EEPROM (for example, closed) I think this is how I can solve this problem
Full sketch:
int s1 = D2;
int s2 = D3;
int o1 = D0;
int o2 = D1;
pinMode(s1, OUTPUT);
pinMode(s2, OUTPUT);
pinMode(o1, OUTPUT);
pinMode(o2, OUTPUT);
pinMode(D1, INPUT);
//If the value in the EEPROM is closed
if (digitalRead(D1) == HIGH) {
digitalWrite(s1, HIGH);
delay(4000);
digitalWrite(s1, LOW);
//If the value in the EEPROM is open
digitalWrite(s2, HIGH);
digitalWrite(s2, LOW);
int s1 = D2;
int s2 = D3;
int o1 = D0;
int o2 = D1;
#include <EEPROM.h>
char buffer[100];
char valueOnEeprom[100];
pinMode(D1, INPUT);
delay(4000);
//Write the word "close" in the EEPROM
//Write the word "open" in the EEPROM
Yes, I have read and used EEPROM before for other purposes. Then I wrote down the numbers.
But now, at this moment, I don't understand how to write down a word, and then compare it and do something.
int s1 = D2;
int s2 = D3;
#include <ezButton.h>
ezButton limitSwitch(D4);
ezButton limitSwitch2(D1);
pinMode(D5, INPUT);
limitSwitch.setDebounceTime(50);
limitSwitch2.setDebounceTime(50);
limitSwitch.loop();
int state = limitSwitch.getState();
if (state == LOW) { //The motor turns and stops when button 1 is pressed
Serial.println("asd1");
limitSwitch.loop(); // MUST call the loop() function first
int statee = limitSwitch2.getState();
if (digitalRead(D5) == 0) { //if there is a touch
//if (state == LOW){ The first button is activated
//digitalWrite(s2, HIGH); turn the motor back
//if (statee == LOW){
//{digitalWrite(s2, LOW);} Turn until the button 2 is activated
// if (statee == LOW){ and if the second button is activated
// digitalWrite(s1, HIGH); turn the motor back
// if (state == LOW){digitalWrite(s1, LOW);} Twist until 1 button is activated
The limit switch shouldn't really make the motor change direction. The job of the limit switch in this scenario is to let the software know that an object (in this case the barrier) has reached a predetermined position.
Your project may benefit from a simple state machine such that:
State 0: UNKNOWN - the barrier is not fully up or fully down (usually at power on)
State 1: DOWN - the down limit switch is activated
State 2: GOING_UP - barrier is moving up & waiting for up limit switch to activate
State 3: UP - the up limit switch is activated
State 4: GOING_DOWN - barrier is moving down & waiting for the down limit switch to activate.
You can achieve this with a simple switch statement.
Your touch button will then perform a different function depending on which state your barrier is in.
In state 1, touching the button moves the barrier to state 2 where you activate the motor to raise the barrier. In state 3, touching the button moves the barrier to state 4 where you activate the motor to lower the barrier.
In state 2, you look for the up limit switch and when it is activated, you stop the motor and move to state 3. Similarly in state 4, you look for the down limit switch and when it is activated, you stop the motor and move to state 1.
Thank you for the detailed information!
Difficulties and questions appeared during the execution.
The previously agreed 5 position of the button are all inside the switch case?
I mean, the state is UNKNOWN, shouldn't it be in setup?
switch (var) {
case 1:
if (state == HIGH && statee == HIGH)
Ok, here's a bit of untested code that I quickly put together that should demonstrate the use of a simple state machine. You will need to tweek it for your specific limit switch and touch switch connections and insert your code that activates your motor.
enum barrierStates {
UNKNOWN,
DOWN,
GOING_UP,
UP,
GOING_DOWN
enum barrierStates barrierState;
const uint8_t upLimitSwitchPin = 4; // UNO pin 4
const uint8_t downLimitSwitchPin = 5; // UNO pin 5
const uint8_t touchSwitchPin = 6; // UNO Pin 6
uint8_t upLimitSwitch;
uint8_t downLimitSwitch;
uint8_t touchSwitch;
uint8_t prevTouchSwitch;
pinMode( upLimitSwitchPin, INPUT_PULLUP );
pinMode( downLimitSwitchPin, INPUT_PULLUP );
pinMode( touchSwitchPin, INPUT_PULLUP );
delay(100);
touchSwitch = digitalRead( touchSwitchPin );
prevTouchSwitch = touchSwitch;
// a HIGH here means the limit switch is open
upLimitSwitch = digitalRead( upLimitSwitchPin );
downLimitSwitch = digitalRead( downLimitSwitchPin );
// determine the initial barrier position
if ( upLimitSwitch == LOW && downLimitSwitch == LOW ){
Serial.println(F("ERROR - both limit switches activated"));
while(1);
else if ( upLimitSwitch == HIGH && downLimitSwitch == HIGH ){
barrierState = UNKNOWN;
Serial.println(F("BARRIER POSITION UNKNOWN"));
else if ( upLimitSwitch == LOW ) {
Serial.println(F("BARRIER UP"));
barrierState = UP;
else {
Serial.println(F("BARRIER DOWN"));
barrierState = DOWN;
// assume HIGH = switch touched
switch ( barrierState ) {
case UNKNOWN:
// INSERT YOUR CODE TO ACTIVATE MOTOR TO MAKE BARRIER GO UP
// INSERT YOUR CODE TO STOP MOTOR
barrierState = UP;
case DOWN:
if (( touchSwitch != prevTouchSwitch ) && ( touchSwitch == HIGH ) ) {
Serial.println(F("BARRIER GOING UP"));
barrierState = GOING_UP;
case GOING_UP:
barrierState = UP;
case UP:
// INSERT YOUR CODE TO ACTIVATE MOTOR TO MAKE BARRIER GO DOWN
Serial.println(F("BARRIER GOING DOWN"));
barrierState = GOING_DOWN;
case GOING_DOWN:
if ( downLimitSwitch == LOW ) {
I have one question. What to do if, in the process of closing or opening, the barrier rests against an object and this does not allow the process to be completed. How can I set a timer for 5 seconds in this case?
That is, after 5 seconds, it does not return to the specified button, the touch touch allows itself to be pressed again.
For example: pressed the touch the barrier opens and he cannot fully open the object rests. After 5 seconds, if you press touch, it is back
Generally I guess you would have either sensors on the barrier or a way of monitoring the motor current to detect that the barrier has come into contact with another object. You would probably want to know quicker than 5 seconds that the barrier has hit an object, otherwise you risk damaging that object and/or burning out the motor.
You could then either simply stop the barrier where it is or get it to reverse its direction.
You could add 2 new states: GOING_UP_OBJECT_IN_WAY and GOING_DOWN_OBJECT_IN_WAY.
When you are in GOING_UP and you detect an object in the way, you enter the GOING_UP_OBJECT_IN_WAY state. Here you decide what to do next, how long to wait etc. Same for GOING_DOWN.
Thanks!
But in my case, the barrier sometimes has to collide with an object. And the engine should not stop and turn on until the end.
And if the barrier does not return to the button within 5 seconds after opening, the touch touch allows you to press again on your own.
