EEPROM Assignment problems
Over the last week I have studied everything I could find about EEPROM and reading and writing to it the following program is returning unexpected values and after a week I still cant figure out where I am going wrong. The code is supposed to ask a user for a command and then execute either read or write to the EEPROM. I would appreciate any guidance, I know I must be missing something.
#include <EEPROM.h>
Serial.begin(9600);{
while(!Serial);
; //wait
int funct_One=0; // Buffer read var
int addr_One=200; // User input for address
int EEVal_One=0; // EEprom results
Serial.flush();
Serial.write(" Type the command to read or write to EEPROM \n ");//Print the directions to serial monitor
delay(10000);
for(int i=0;i<2;i++){
if(Serial.available() > 0){
funct_One=Serial.read();
Serial.println(funct_One);
if (funct_One==114)//Is read = to 114 the number for the word read??
Serial.print("Enter an address to read betwwen 0-1023 \n ");
delay(10000);
if (Serial.available() >0){
addr_One = Serial.read();
Serial.println(addr_One);
Serial.flush();
EEVal_One = EEPROM.read(addr_One);
Serial.write("The value at your memory address is " );
Serial.println(EEVal_One, DEC);
Serial.flush();
for (int x; x<=1; x++){
if(funct_One!=114){ //119 is the word write
int addr_Two;
int funct_Two;// var for code def
int val_One;
funct_One = funct_Two;
Serial.flush();
Serial.print("Please enter an address to write \n");
delay(10000);
if (Serial.available () >0){
addr_Two = Serial.read();
Serial.flush();
Serial.print( "Please provide a value less than 9999 to write \n" );
delay(10000);
if (Serial.available() >0) {
val_One=Serial.read();
Serial.flush();
EEPROM.write(addr_Two,val_One);
Serial.print("You have written a memory address of \n");
Serial.print((addr_One));
Serial.print(" with a value of ");
Serial.print((val_One));
} break;
Serial.end();
Please use code tags (</> button on the toolbar) when you post code or warning/error messages. The reason is that the forum software can interpret parts of your code as markup, leading to confusion, wasted time, and a reduced chance for you to get help with your problem. This will also make it easier to read your code and to copy it to the IDE or editor. If your browser doesn't show the posting toolbar then you can just manually add the code tags:
[code]``[color=blue]// your code is here[/color]``[/code]
Using code tags and other important information is explained in the How to use this forum post. Please read it.
Please always do a Tools > Auto Format on your code before posting it. This will make it easier for you to spot bugs and make it easier for us to read. If you're using the Arduino Web Editor you will not have access to this useful tool but it's still unacceptable to post poorly formatted code. I recommend you to use the standard IDE instead.
Please remove unnecessary blank lines from your code before posting to the forum. One or two to separate code into logical sections is fine but large spaces for no reason or random blank lines just make for more scrolling when we're trying to read your code.
DemonBadger:
That's not a sufficient description of the problem.
when I type in the word read on the serial monitor what is written to the variable funct_One is 114, when I type in the word write to the serial monitor what is written in the variable funct_One is 119,
then for some reason when the question gets asked in serial monitor to "enter and address it is 97
but the address in my code was hard coded to be EEPROM address 200, I wanted to see if there was some issue with Serial.read and because the variable is declared prior to the Serial.read somehow the variable retains the original value from when it was declared. I am extremely frustrated but not sure where I am going wrong. Am I missing a calculation or a function to convert data, is there a function call that is incorrect. I am prepared to learn it I just don't know what it is that I am missing or not understanding.
here is my code:
#include <EEPROM.h>
  while(!Serial);
  ;              //wait
       Serial.flush();
       delay(10000);
      delay(10000);
         Serial.flush();
         Serial.flush();
  int addr_Two;
  int val_One;
  Serial.flush();
  delay(10000);
  Serial.flush();
   delay(10000);
    Serial.flush();
} break;
Serial.end();
pert:
here is my code:
#include <EEPROM.h>
  Serial.begin(9600); {
    while (!Serial);
    ;              //wait
  int funct_One = 0; // Buffer read var
  int addr_One = 200; // User input for address
  int EEVal_One = 0; // EEprom results
  Serial.flush();
  delay(10000);
  for (int i = 0; i < 2; i++) {
    if (Serial.available() > 0) {
      funct_One = Serial.read();
    if (funct_One == 114) //Is read = to 114 the number for the word read??
      delay(10000);
        Serial.flush();
        Serial.flush();
    for (int x; x <= 1; x++) {
      if (funct_One != 114) { //119 is the word write
        int addr_Two;
        int val_One;
        Serial.flush();
        delay(10000);
        if (Serial.available () > 0) {
          Serial.flush();
          delay(10000);
          val_One = Serial.read();
          Serial.flush();
          EEPROM.write(addr_Two, val_One);
        } break;
    Serial.end();
I apologize for the poorly formatted code, I am trying to learn to code. Thank you for the advice on formatting I have implemented your suggestions here:
#include <EEPROM.h>
    while (!Serial);
    ;              //wait
  Serial.flush();
  delay(10000);
      delay(10000);
        Serial.flush();
        Serial.flush();
        int addr_Two;
        int val_One;
        Serial.flush();
        delay(10000);
          Serial.flush();
          delay(10000);
          Serial.flush();
        } break;
    Serial.end();
  delay(10000);
What if the users doesn't respond within 10 seconds?
Don't rely on delay
Thank you for the comments,
With respect to the delay I would like to learn another way to wait for input from the user but nothing I have looked at provides me with an alternative. Is there a switch that will make the serial monitor wait, something I am missing?
funct_One variable outputs 114 when I ask the program to print the variable I have tried to match inputs to the ACSII table. I am just not sure where the data is coming from four letters "read" produces 114 in the program why?.
My understanding of serial flush is that it clears the serial buffer. Is this not correct?
thank you, I will read the serial inputs basics thread and see where that leads me. The 114 is what happen from the line 21-" serial.println funct_One" the result is 114.
Ok, so the serial read is reading a byte, but I need it to read an array? So can I declare a global variable as a const byte of say 16. So the serial read function needs to be a serial.readBytes(16)
