eeprom button register
const int button = 4; // start:
const int led2 = 9; // exit:
const int led3 = 10; // button
int butonium = 0; // set location:
int value = 0;
void setup ()
pinMode(buton, INPUT);   // start :
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
void loop ()
  button = digitalRead (button);
if ((button == HIGH) && (value == 0)) // button bast: // // button state variable:
digitalWrite (led2, LOW);
digitalWrite (led3, HIGH);
value = 1;
delay (10);
if ((button == LOW) && (value == 1)) // // Button left:
value = 2;
delay (10);
if ((button == HIGH) && (value == 2)) // button bast:
digitalWrite (led2, HIGH);
digitalWrite (led3, LOW);
value = 3;
delay (10);
if ((button == LOW) && (value == 3)) // // Button left:
value = 4;
delay (10);
if ((button == HIGH) && (value == 4)) // // Button bast:
value = 5;
delay (10);
if ((button == LOW) && (value == 5)) // // Button left:
value = 0;
delay (10);
Hi
2 leds with one button
I’m burning in order but when the energy is cut off
I want the last LED usage to remain
How to write an eeprom record
Can you help for the program
Have you looked at the EEPROM examples in the IDE ?
UKHeliBob:
UKHeliBob:
ardunio pro mini or nano
for the program with
I did not look at the IDE
can you direct it for simple application
thanks
I assume that you cannot find the EEPROM examples
They are in a very obvious location
File->Examples->EEPROM
