Hello all
I’ve learned Arduino and I was interested in trying to make RFID access control project is currently trying to get a clear eeprom expamle from libraries i have compiling problem Can someone help how the solution
* EEPROM Clear
* Sets all of the bytes of the EEPROM to 0.
* Please see eeprom_iteration for a more in depth
* look at how to traverse the EEPROM.
* This example code is in the public domain.
#include <EEPROM.h>
// initialize the LED pin as an output.
pinMode(13, OUTPUT);
Iterate through each byte of the EEPROM storage.
Larger AVR processors have larger EEPROM sizes, E.g:
- Arduno Duemilanove: 512b EEPROM storage.
- Arduino Uno: 1kb EEPROM storage.
- Arduino Mega: 4kb EEPROM storage.
Rather than hard-coding the length, you should use the pre-provided length function.
This will make your code portable to all AVR processors.
for (int i = 0 ; i < EEPROM.length() ; i++) {
EEPROM.write(i, 0);
// turn the LED on when we're done
digitalWrite(13, HIGH);
/** Empty loop. **/
Using library EEPROM at version 2.0 in folder: C:\Program Files\Arduino\hardware\arduino\avr\libraries\EEPROM
exit status 1
Error compiling for board Arduino/Genuino Uno.]
