I dont know if it is the right place to put my issue here, because its a bit complicated, so sorry for that if its so.
i created my own arduino nano low power version. see pic
if any one is interested in the EAGLE FILE, i will upload it.
the board is working fine so far. the code (relevant parts shown) used is already tested before with standard arduino nano. no problems so far. in short, i first upload a sketch via USB where i write 2 float variables in to the EEPROM. after that i upload a sketch where it reads the floats from EEPROM and saves them to the variables Min and Max. and then i display the values on the LCD(with I2c). in standard opperation of the device i need to change these values by buttons and then save them to EEPROM again for use after reboot.
Now here is the Problem:
If i Upload the code via ISP-Programmer AVRISP MKII to my custom arduino the LCD freezes with black bars forever (ireversible, even if i upload a working sketch) and the arduino freezes too, i cant even reset the atmega. if i delete the EEPROM lines in the sketch, remove the lcd and upload to the same arduino and replace to a new LCD Display, it is working again. i am using an ATMEGA 328PB on my custom arduino. i destroyed 2 lcd until i found the problem. i have no clue whats going on here and i am not very experienced in programming. if anyone has an idea i would be very thankful!
#include "HX711.h" // GitHub - bogde/HX711: An Arduino library to interface the Avia Semiconductor HX711 24-Bit Analog-to-Digital Converter (ADC) for Weight Scales.
#include "Wire.h"
#include <LiquidCrystal_I2C.h> // GitHub - johnrickman/LiquidCrystal_I2C: LiquidCrystal Arduino library for the DFRobot I2C LCD displays
#include "math.h"
#include <ButtonDebounce.h>
//#include <EEPROM.h>
#include "LowPower.h"
float Min = -5.0;
float Max = -3.0;
//float Min = EEPROM.get(0, f);
//float Max = EEPROM.get(4, f);
LiquidCrystal_I2C lcd(0x27, 16, 2);
// Serial.begin(115200);
// float Min = -5.0;
// float Max = -3.0;
// EEPROM.put(0,Min);
// EEPROM.put(4,Max);
lcd.init(); //Im Setup wird der LCD gestartet
lcd.backlight(); //Hintergrundbeleuchtung einschalten (0 schaltet die Beleuchtung aus).
lcd.setCursor(0, 0);
lcd.print(" ");
lcd.setCursor(7, 0);
lcd.print(">Min=");
lcd.print(Min, 1);
lcd.setCursor(7, 1);
lcd.print(" Max=");
lcd.print(Max, 1);
